Author Topic: De rusting with electrolysis (sp)  (Read 7929 times)
Offline SteveW
« on: October 06, 2013, 05:26:11 PM »
Could be helpful with some projects. I got a 14" cast iron skillet that was laying in the ground at a customers house. it was in pretty bad shape. They didn't want it and the previous owner had used it for catching the dripping from their outdoor grill and just left it. I cleaned most of the big stuff with a sander and steel wool and tried a couple other things but it still wasn't usable. I looked at some rust removal on You-tube and decided to give it a shot.
here is skillet
Here is set up, a plastic tub, some angle iron and 10 awg copper wire
Prior to solution, you don't want it too far away from positive metal but don't want it to touch either. This was just stuff on hand I used
Solution is just water and Borax powder probably about 1lb to start and just mixed it with a stick. negative to skillet and positive to wire 10 amps selected on charger
When you get it bubbling like this it is doing a good job, you can also look and see bottom being covered in rust. This was left alone for 13 hours
See the difference. That was an 18 gallon tub and skillet didn't fit
It cleaned up well and washed with hot water, oven dried and then seasoned with shortening. The smaller piece was in for 5 hours to clean
One day she will look like a proper skillet
I cooked 95 ounces of hash in it for a group of people from my Church who go camping over Thanksgiving Holiday 16 people and nothing left. We scrambled 18 eggs in it and it would hold 3 dozen easy. 2 things a cook likes is an empty pot and no talking when your food is being eaten :)
« Last Edit: October 06, 2013, 05:30:42 PM by Googly_Moogly »
Offline SteveW
Re: De rusting with electrolysis (sp)
« Reply #1 on: October 06, 2013, 05:34:32 PM »
Not sure where to put this so if it is in wrong place please move it. You need to do this outside also as it makes a gas which eludes me right now and is not suitable for an indoor area. It is extremely inexpensive method and requires very little time.
Offline johnrb3b
    • Jeeps and stuff
« Reply #2 on: October 09, 2013, 01:30:02 PM »
Nope, no problem, this was the right place.
A very interesting project.
I love cast iron as well.
I've been using a cast iron griddle to make pancakes for several decades.
At one point, about 35 years ago, I gave my set of 3 frying pans to a friend. I later regretted it. We've bought two cast iron pans in the last few years. Going full circle.
Offline SteveW
« Reply #3 on: October 09, 2013, 02:29:01 PM »
Here is my collection as of now. Mostly new Lodge stuff but have some Wagner and Griswold iron as well. it would also have applications to clean parts on jeep items as well as other metal objects. I have gotten better metal pieces (rebar) for set up and going to try it on some parts for my trailer coming up.
I can feed about 200 folks I believe 8-)
Offline SteveW
« Reply #4 on: August 21, 2014, 08:27:29 PM »
Here is a link to using it on other than cast iron so for tools and parts it will do the job
http://g503.com/forums/viewtopic.php?f=48&t=241561
That is my set up with 4 rebars and improved wire and connections so I am set with it
« Reply #5 on: August 22, 2014, 06:13:24 AM »
