Author Topic: 1950 cj-3a restoration mostly stock with kubota  (Read 48694 times)
Offline corpsman
Re: 1950 cj-3a restoration mostly stock with kubota
« Reply #30 on: February 16, 2015, 11:49:17 PM »
thanks!  yeah, I think it's just plain cool to have that pic.  I wish I had more old ones like that of the jeep.  the mirror is still on it.  you can definitely tell he used his jeep.
1952 M38
« Reply #31 on: February 17, 2015, 06:00:37 AM »
Old photos like that are great!!!
« Reply #32 on: February 17, 2015, 01:32:20 PM »
�And the rear hub is the same color as the wheel.�
The studs and nuts look to be the same color too.  Is it possible the rear wheel is just covered in wet mud?
The pin striping isn�t showing as clear as the front wheel striping.
Offline corpsman
« Reply #33 on: February 17, 2015, 01:56:54 PM »
 yeah, I didn't even notice the pin striping.  I'm thinking that might be dust and dried mud.
1952 M38
Offline corpsman
« Reply #34 on: February 24, 2015, 09:34:01 PM »
sorry, guys.  nothing to report as of lately.  we're still having crummy weather here in Tennessee.  I'm hoping to do a little something this weekend.  I think I'm beginning to have Jeep Withdrawal.  :D  :-/
1952 M38
Offline JeepFever
« Reply #35 on: February 24, 2015, 11:49:04 PM »
Yeah,� crummy weather all around.� � :(� �definately slowing project progress.
I just now noticed this thread,� including the post with old photo of Eddie Arnold.� (great photo!)� . .� �It has me puzzled though - >� in the recent "factory tire" thread,� Ryan posted some photos of a NDT style tire as original,� but this 1952 photo (although blurry) appears to be a more "civilian" type tread?
« Last Edit: February 24, 2015, 11:50:29 PM by JeepFever »
Offline corpsman
« Reply #36 on: February 25, 2015, 09:37:21 AM »
i don't know.� the Jeep would have been 2 years old at that point.� maybe he put some different tires on it.  hard for me to tell, but it looks like mis-matched tires to me.  the front looks like a military non-directional.  the rear looks like some sort of civilian mud terrain tire.
« Last Edit: February 25, 2015, 09:39:31 AM by corpsman »
1952 M38
Offline corpsman
« Reply #37 on: February 28, 2015, 08:47:14 PM »
the temperature finally rose enough to get out in the shop and do a little work on the jeep.  didn't do much, but I managed to get the rear axle clean enough to begin disassembly.  I had to stop there because I want to determine if the axles are threaded differently like the lug studs before I attempt to remove the axle nuts.  seems like they are way too tight, but I don't have any experience with a "stick" axle.  all of my previous experience is with "flange" axles.  (Toyota and Samurai)
1952 M38
« Reply #38 on: February 28, 2015, 09:40:01 PM »
One side is left hand thread. Look on the end of the studs. One side will have an L stamped on them. You need a special tool to bull the hub off the rear axles.
Offline corpsman
« Reply #39 on: February 28, 2015, 11:54:18 PM »
I know the lug studs are stamped on the end, but I'm wondering if the axle threads are the same way.� do you really need the tool, or is there another way to remove the hub?  also, I found a side cut-a-way view of the rear hub and axle.  i guess the axle nut was tight because the axle is tapered.  all that seems like a weird set up to me.
« Last Edit: March 01, 2015, 12:05:18 AM by corpsman »
1952 M38
« Reply #40 on: March 01, 2015, 06:35:00 AM »
Do you have a 3A service manual? If not, you may want to pick one up - you'll be glad you did. The diagrams and instructions are very helpful for stuff like this. You can also sign up at http://willysmjeeps.com and gain access to a large collection of M38 manuals - much of which applies to the 3A.
I think the chances of damaging something trying to remove the drum without an appropriate puller wouldn't be worth the risk. You are probably aware of how they work but here's a good video from Walck's showing how it's done.
[media]http://youtu.be/PQQvFK4B6pY[/media]
« Last Edit: March 01, 2015, 06:36:10 AM by Ryan_M »
« Reply #41 on: March 01, 2015, 08:35:24 AM »
I know the lug studs are stamped on the end, but I'm wondering if the axle threads are the same way.� do you really need the tool, or is there another way to remove the hub?� also, I found a side cut-a-way view of the rear hub and axle.� i guess the axle nut was tight because the axle is tapered.� all that seems like a weird set up to me.
Both axle shaft nuts are RH thread. A lot of old vehicles had axles that were two piece like that. Just a common thing in 1930-1940 vehicles at the time.
Offline corpsman
« Reply #42 on: March 01, 2015, 12:45:56 PM »
the only service manual I have, is the one that probably came with the jeep when bought new.� it's definitely not the greatest.� yeah, I should probably think about picking one up.� thanks for the link and video.
« Last Edit: March 01, 2015, 12:46:26 PM by corpsman »
1952 M38
Offline corpsman
« Reply #43 on: March 01, 2015, 12:47:03 PM »
thanks!
1952 M38
Offline corpsman
« Reply #44 on: March 08, 2015, 09:46:07 PM »
due to cold and snowy weather, I haven't been able to do much lately.  so, finally today I was able to get out to the shop and make a little progress.  I pulled both rear hubs, drums, axles, and all associated parts.  I'm trying to let as much of the goo drain out of the diff as possible.  the next order of business will be to pull all of the components out of the differential.
1952 M38
