Author Topic: 1950 cj-3a restoration mostly stock with kubota  (Read 48699 times)
Offline corpsman
Re: 1950 cj-3a restoration mostly stock with kubota
« Reply #15 on: February 09, 2015, 10:49:04 PM »
Herm is the overdrive guy!
http://hermtheoverdriveguy.com
You can also check the our website. Jonathan did put a lot of great info about it;
Here is about the installation ;
http://www.cj3apage.com/index/My_1950/installing_an_overdrive.htm
Enjoy!
thanks for the link.  that guy has a great page.  I definitely plan on getting one of those over-drive units.  i'll probably end up getting some other stuff.  I'm sure my transmission and transfer case need to be rebuilt.  anyway, thanks again for the info!
« Last Edit: February 10, 2015, 12:03:22 AM by corpsman »
1952 M38
Offline corpsman
« Reply #16 on: February 09, 2015, 10:54:44 PM »
made some progress today after work.� removed engine/tranny/transfer case, front driveshaft, shocks, brake lines, cross member, front weight, and a bunch of other crap.� the only thing left to do before the frame is bare, is unbolt the springs and roll the diffs out as a unit.�
« Last Edit: February 09, 2015, 10:55:22 PM by corpsman »
1952 M38
Offline corpsman
« Reply #17 on: February 11, 2015, 12:46:54 AM »
front and rear springs disconnected, diffs out, ready to be blasted with crushed glass.
1952 M38
Offline corpsman
« Reply #18 on: February 11, 2015, 10:14:53 PM »
I bought some seats for the jeep the other day.  they came out of a 90's mazda Miata.  got both for $45.
1952 M38
Offline corpsman
« Reply #19 on: February 14, 2015, 09:50:46 PM »
ready to be blasted.  I figured I would clean it up pretty good so hopefully, the guys at the blasting place would have more time to do a better job.  I was pretty surprised at how well the wire cup from harbor freight worked.
1952 M38
« Reply #20 on: February 14, 2015, 10:05:35 PM »
You stripped that fast!
Offline corpsman
« Reply #21 on: February 15, 2015, 04:31:50 AM »
thanks!  it was a lot of work, but I just keep thinking about how it will look once I am finished.  of course it's a little early to say this, but I'm having so much fun, I may have to do another one when I finish this one.  I suppose the floor on the body will slow my roll quite a bit.
1952 M38
« Reply #22 on: February 15, 2015, 02:10:54 PM »
I'm probably a tad further along in my project than you, and I am already thinking about the next one. Apparently these things multiply on you pretty fast�
Nice Job!
Offline corpsman
« Reply #23 on: February 15, 2015, 09:56:15 PM »
thanks!  I'm the same way...  already thinking about the next one.
1952 M38
Offline corpsman
« Reply #24 on: February 15, 2015, 11:51:42 PM »
here's a copy of a picture of Eddy Arnold sitting in the jeep that I currently own featured in this thread.  copy didn't turn out too good, but the license plate is dated 1952.
1952 M38
« Reply #25 on: February 16, 2015, 01:03:05 PM »
That's a great old photo.
Your frame looks to be in very nice condition.
Your tub... Well, I've seen guys here fix stuff that was way worse.
Looks like a fun project to follow.
« Reply #26 on: February 16, 2015, 01:13:48 PM »
Great picture!
And the side step is already bent!
« Reply #27 on: February 16, 2015, 02:39:26 PM »
I saw that!  I also noticed the banged up license plate.  A common complaint from many of us�60 years later.
Offline corpsman
« Reply #28 on: February 16, 2015, 05:45:59 PM »
yeah, that side step is just asking to get bang up on some rocks or logs.  the side steps were ditched sometime before the jeep became mine.  it's okay, because I wouldn't have used them anyway.  yeah, the frame doesn't look bad at all.  I spent a lot of time cleaning it so the guys at the blast place could have time to do a better job instead of dealing with all that mud and grease.  the tub is pretty bad underneath, but yes, I've seen guys on here tackle much worse.  it will go slow, but I can do it.  thanks for the compliments on the picture.  I thought it was pretty neat also.
1952 M38
« Reply #29 on: February 16, 2015, 09:52:45 PM »
I really like old pictures like that....you can see that the "Willys" on the hood is painted, perhaps wheel color. And the rear hub is the same color as the wheel.....long arm on the rear view mirror, and there doesn't appear to be an inside mirror...pretty neat
And it looks like Eddy really used the jeep..cool
