Author Topic: New flatfender owner in CO  (Read 6226 times)
Offline MGYs
« on: March 29, 2018, 08:37:07 PM »
Greetings,all!
I've been looking in here for awhile, as I gathered up parts to start my retirement project - a 1951 M38 I'm rebuilding as a CJ3A. Now that I'm retired it's time to get to it, so please allow me to kick off my project by introducing myself. I'm David T from Thornton, CO. I like puppies, chinese food, and long walks in th.....whoa, wrong website! ::)
 I like flatfenders, altitude, and fold-down windshields. More later.
Re: New flatfender owner in CO
« Reply #1 on: March 29, 2018, 08:58:07 PM »
Hi David, welcome to the 3A page.  Would love to see a pic of your project.  I'm in Fort Collins and Athawk (Tim) is in Arvada.  And a bunch of other Colorado guys here and there.  Hawky went the other way - he has a 3A that he built into a beautiful M38.  And I have an M38 on a 3A frame.  Go figure!
Offline MGYs
« Reply #2 on: March 29, 2018, 09:19:14 PM »
Thanks, and let's see if I can do this.
« Reply #3 on: March 29, 2018, 09:22:14 PM »
Welcome David.� Sounds like a fun project to watch.� Learn how to post photos and show us your progress.� Congratulations on your retirement.
As Tom mentions, we are all a lttile mixed up around here. :)
Edit: Success! I see your photo.  Looks like a really nice start.
« Last Edit: March 29, 2018, 09:23:33 PM by athawk11 »
Offline MGYs
« Reply #4 on: March 29, 2018, 10:03:23 PM »
Thanks Tim. The M38 body went to Larry in Windsor, CO. I have a replacement CJ3A tub in the garage. I've got the frame boxed and suspension hung, and I'm swapping out the drums for discs. Next up is the steering kit from Herm the Overdrive Guy, and a 4.3 W-code/4L60E with a Novak adapter.
Offline MikeB
« Reply #5 on: March 29, 2018, 10:56:05 PM »
Nice looking project. I have a M38 with a 4.3 and the Novak kit. What gear box are you using ?
Offline MGYs
« Reply #6 on: March 29, 2018, 11:31:29 PM »
Thanks, MikeB. I'll probably want to be PMing you to bounce my ideas about the swap. Hope that's OK. I want to do a 4L60E automatic tranny with the Novak and the stock Spicer T-case. Novak says a TH350 is the only "practical" choice for the short wheelbase early CJs. Overall length of the 4L60E combo w/adapter is only 2" more than the TH350 w/adapter. I'll get the group opinion when I'm ready to weld the motor mounts on. Until then, lots of other things to do!
Offline MikeB
« Reply #7 on: March 30, 2018, 11:51:41 AM »
Well my M38 started out blue when I first got it also. I�m running the 4.3 with the TBI, w series and a sm465 gearbox and D300 t-case. All fits nicely under the stock frame and body, you will need to put at least a 3/4� body lift to clear the motor, and go with a electric slimline fan as the mechanical fan on the motor sticks out to far, unless you want to move your grill forward a few inches, but that involves more work that it sounds.  With the whole motor tranny combo stock axle shafts will be too long so you�re going to need to source others, either custom or from a doner vehicle.
Offline MGYs
« Reply #8 on: April 02, 2018, 11:43:29 AM »
Hmmm. I was under the impression that W code engines had multi-port injection, thus a distinctive engine code. I'll have to research that a little bit deeper
With the whole motor tranny combo stock axle shafts will be too long.
Not trying to nitpick, I just want to have a thorough understanding of the project I'm undertaking - did you by any chance mean the stock driveshafts?
Your info is extremely valuable to me, Mike B, please don't take offense. Thanks
David T
Offline MikeB
« Reply #9 on: April 08, 2018, 01:42:00 PM »
My humble apologies I missed typed axle shafts when I ment drive shafts.
As for the W code motor (block code), I believe they came in TBI and direct port, depending on the year, but I could be wrong. you get a little more clearance with the TBI as the throttle body is raised on the direct port 4.3, you can squeeze in a cut down air plenum with a TBI and not have to use a bigger body lift or cut the hood and add a scoop, to clear the taller direct port intake.  Although a extra inch of clearance would be nice on my set up as getting to the ICM and dizzy is a PITA as it is.
« Last Edit: April 08, 2018, 01:45:10 PM by iron_mike »
Offline MGYs
« Reply #10 on: April 08, 2018, 03:46:28 PM »
SWEE-EE-EET!
Is that the stock radiator in yours?  I just cut the battery tray from the frame yesterday, thinking that I couldn't possibly get the motor in.
Any way you slice it, that's a nice look on yours, MikeB!
Offline MikeB
« Reply #11 on: April 08, 2018, 07:03:55 PM »
The 4.3 fits nicely under the hood, the fact we can take the grill and fenders off makes the install much easier, plenty of room for the battery tray.� Here is a pick of test fitting the motor.
Yes it is the original radiator, had it re-cored, haven�t had a issue with over heating.
« Last Edit: April 08, 2018, 07:06:28 PM by iron_mike »
Offline MGYs
« Reply #12 on: April 09, 2018, 02:46:37 AM »
That's the first real perspective I've gotten on fitment of the 4.3, thanks. And you are correct, the first W (and Z) code motors were TBIs, in 96 they went to the spiders.
I sawzalled the battery tray welds right up against the frame after punching out the rivets of the right motor mount, so I can finish detaching it from the mount and weld the tray back in if I so desire - and I probably will after seeing yours!
I'm going with a dual reservoir master cylinder conversion kit, no vacuum assist for the discs, and a Ross power reverse steering kit, donor Ford Ranger over a Saginaw box. I should have pictures by the end of the week.
Thanks for the pics, MikeB!
« Reply #13 on: April 27, 2018, 08:10:18 PM »
Welcome Aboard!
« Reply #14 on: April 28, 2018, 02:47:12 PM »
MGY, are you sure that is an M38?  I only ask as I don't see a fuel tank opening in the driver side.  Could it be you have an MB or GPW???  Or maybe a PO just decided to relocate the tank?
