Author Topic: Hello from Chicago  (Read 9960 times)
Offline Casey
Re: Hello from Chicago
« Reply #15 on: September 20, 2016, 11:44:40 AM »
1998 TJ 4.0L 5.5" Lift 33s Other Mods (Sold)
2015 WK2 5.7L Fully-loaded Stock
1948 Willys CJ-3A F134 2" Lift 31s
Offline Casey
« Reply #16 on: September 20, 2016, 11:44:58 AM »
Offline Casey
« Reply #17 on: September 20, 2016, 11:45:13 AM »
Offline Casey
« Reply #18 on: September 20, 2016, 11:45:28 AM »
Offline Casey
« Reply #19 on: September 20, 2016, 11:45:42 AM »
Offline Casey
« Reply #20 on: September 20, 2016, 11:45:56 AM »
« Reply #21 on: September 20, 2016, 11:42:08 PM »
You have a lot going on there.
-The sheet metal is early MD Juan reproduction.
-Dana 44 rear axle and Dana 25 front axle suggests a later CJ3A or M38.
-You already knew the engine is a transplant.
-The seat frames are not original, but look like a pretty nice modification.
-Radiator is a 2A...early 3A or M38.  A slightly different view would help narrow it down.
-The body tag doesn't look right.  I'm not sure what's going on there.
-The front wheel looks like an original Kelsey Hays 15" wheel.  Not sure where the rear wheel belongs.
-The frame is a 3A.
It's a real nice rig overall.  Because of the frame and the axles, I would probably say it is a CJ3A.
Offline Casey
« Reply #22 on: September 22, 2016, 08:59:55 AM »
Awesome input, thanks!
What are your thoughts on this engine... I'd like to identify it, any ideas where I may find some markings to help? I'm going to get out there and crawl around this afternoon to see what I can find...
« Reply #23 on: September 22, 2016, 11:39:13 PM »
The engine is a Willys Hurricane.  Also called an F-134.
This is a fairly common and relatively easy swap.  They are compatible with the 3A frame and the rest of the drive train.  If you see a Willys flat fender with a hole in the hood, it probably has an F-134.
This engine is originally found in the CJ3B, M38A1 and the CJ5...among other Willys and Kaiser models.  It's a good engine...with more horsepower than the original L-134 Go Devil.
Offline Casey
« Reply #24 on: September 23, 2016, 10:50:44 AM »
You have been a tremendous help! Thank you very much... off to do some more "research".
Offline Casey
« Reply #25 on: February 22, 2017, 09:05:30 PM »
Installed new Superlift leaf springs and shocks over the weekend... Built for a 1" lift but it looks like I ended up with about 2"! Also put in a new Optima Red and full size spare.
