Author Topic: New Member from VA  (Read 3963 times)
Offline JeepFever
New Member from VA
« on: October 26, 2014, 08:59:46 AM »
Hi . .� Ron here from central Virginia
I joined theCJ2Apage.com a couple years ago when I started getting re-interested in old flat-fenders.� �I have enjoyed my trail '2A for over 20 years,� and now starting a new project, '51 CJ3A.� I am going try to keep it as original as possible.
A photo showing it after 10-12 years waiting to become a project.
Here is a photo of it in my driveway.� I had just cut the snowplow frame off of it.� �It looks sad to be so beat up,� but relieved to get that heavy frame removed. ;D
« Last Edit: October 27, 2014, 11:38:57 PM by JeepFever »
Re: New Member from VA
« Reply #1 on: October 26, 2014, 07:57:01 PM »
Sweet, Welcome!
Kirk
« Reply #2 on: October 27, 2014, 10:27:15 AM »
I remember that Willys from the 2A page.  Probably because of the unique bumper. ;)
Welcome to the 3A Page.
« Reply #3 on: October 27, 2014, 07:58:12 PM »
Welcome!
You can attach pics.
Offline JeepFever
« Reply #4 on: October 29, 2014, 12:50:36 AM »
I was able to attach a photo, finally,  but it is an attachment at end of post,  . .   how to I insert it in the body of the message?
ie.  I would like to attach a dozen photos,  each with a description above the photo.
« Reply #5 on: October 29, 2014, 08:40:59 PM »
JeepFever,
There is a good post here, somewhere, with a good description on posting photos.� For some reason, I can't find it.
Bottom line, Photobucket or similar photo hosting site is the easiest way to post multiple photos into one post.� Photobucket is easy to work with.�
1. Join. It's free.
2. Uploaded you photos to Photobucket.�
3. Start a new post here at the 3A.
4. On photbucket they give you a few choices on the type of file you want to use.� Choose the picture from your album.� �Choose the "IMG" option (when you click the IMG code box, it will automatically copy the image code).� Go back to your post at the 3A.� Right click to "paste" the code.� Push the "Preview" button below the message box to confirm the photo or photos shows up.
5. Repeat the copy photo / paste photo as many times as you like.
Note: Things change a little depending on if you are using a PC vs. an IPad.� Some of us have found that you have to delete part of the image code to post more than 3 photos.� This is only true when I use my PC.� If you run into this issue, keep all code that is between [IMG] and [IMG]...including the [IMG]s.� Delete all code between [URL] and [URL]...including the [URL] at both ends of this portion of the code.� It sounds more complicated than it is.� Once you see the photo code it will make perfect sense.
Hopefully I'm helping.� I really want to see lots of photos.� We all do.
Offline JeepFever
« Reply #6 on: October 30, 2014, 12:31:32 AM »
Thanks Tim!
Earlier today I was looking thru the '3A site, and came across your tub building thread. . .  wow,  great info!
While viewing the thread,  I noticed that your write-up looks like what I am hoping to do (photos embedded in text),  and your photos come from links to PhotoBucket . .   I decided that I might give that a try  . . .   you just confirmed that it might be best option.   :)
Offline JeepFever
« Reply #7 on: October 30, 2014, 02:34:09 PM »
Test of Photobucket,� if this works I will start the build thread later.
Some photos in resting place:
Front passenger
Rear passenger
Front with hood down
Rear passenger
Front view . . on the trailer headed home . . early October
Rear view . . on the trailer headed home
« Reply #8 on: October 30, 2014, 03:22:32 PM »
JeepFever,
Looks like you mastered the Photobucket!
Thanks for looking at my build thread.� There certainly have been some challenges.
Your 3A looks like it might need a patch here or there, but for me, these are the really fun ones to watch.� Looking forward to your build.
Tim�
