Author Topic: Engine block numbers  (Read 1307 times)
Offline JSV1956
« on: June 10, 2025, 10:29:00 PM »
I have a F-head engine with numbers and letters on the right lower side of the block can anyone tell me what they mean? The numbers are
806279-W-13-D-AR CUCR
Thanks
Offline Mark W.
  • Chug A Lug
Re: Engine block numbers
« Reply #1 on: June 11, 2025, 12:07:22 AM »
806279 is the series of block
W-13 is the mold number
D  no idea
AR no idea
CUCR Nickle Chromium
Chug A Lug
1948 CJ2A Tub and Title
1949 CJ3A Windshield
1957 CJ5 Frame and Springs
DIY Aluminum Hard top
« Reply #2 on: June 11, 2025, 07:55:41 AM »
Thanks
From previous post:
Quote from: JSV1956
...yes it’s an F-head the numbers on the head are 4J8 1968, I do appreciate the help. Thanks again.
Sorry, I gotta copy/paste to see the post.
JSV1956,
That serial number (starting with 4J) matches jeep engines.  It will sit within the CJ3B database to give a close estimate based on other engines with serial numbers above and below.  My serial number (4J 61346) is the original for my 1954.   I can't see the list right now so maybe some help from our neighbors to see about where it falls.
Unfortunately, a change in carbs could have avoided the hole cut in the hood.
Offline JSV1956
« Reply #3 on: June 12, 2025, 04:13:53 PM »
Thanks for the info. So my engine must be at least a 1954? I bought a china made holly 1904 carb but not had time to install it, I also ordered  a new air horn so I can make some kind of air cleaner, then maybe I can repair the hood or find another one.
Thanks again for all the help.
