Author Topic: WANTED  (Read 2587 times)
Offline Eddie
WANTED
« on: January 15, 2025, 07:27:57 PM »
I need the bolt that keeps the lid on the oil filter. It is a civilian filter. Thanks!
1953 CJ3B
1962 USN CJ3B
1971 Hurst Jeepster
1969 Mustang
Online Rus Curtis
Re: WANTED
« Reply #1 on: January 15, 2025, 08:39:54 PM »
Eddie,
There were several canisters used on the willys CJ's.  This is an image of Buddy Wade's '55.  Does your cansister look like this?
I searched on KW and they offered a bolt that "fits all models" and doesn't look like the one above.
You could reach out to Harry Sheets, http://www.midwestwillys.com/ , verify with him which canister you have and he'll probably have a bolt.  I also noticed McMaster has similar bolts on their site too.
https://www.mcmaster.com/products/flange-bolts/hex-head-screws~/medium-strength-grade-5-steel-flanged-hex-head-screws/
If Harry can't fix you up and you want to go the McMaster Carr route, I can pull my bolt out (same as Wade's above) and measure it.
Offline Ron D
Re: WANTED
« Reply #2 on: January 15, 2025, 10:42:10 PM »
If it helps, here's a kit that includes the bolt and the spring under it. https://www.armyjeepparts.com/p-4334-oil-filter-canister-bolt-spring-set-purolator-military-junior-wwii-jeep-ajp-32145.aspx
Could be mistaken (because I didn't compare part numbers in the books) but think the bolt and spring are common to all the canister filters, military or civilian.
Several vintage military and CJ parts vendors sell them.
Pretty sure a phone call to any of them would get friendly help.
« Last Edit: January 15, 2025, 10:44:16 PM by Ron D »
1951 M38
1951 M100
Online Rus Curtis
Re: WANTED
« Reply #3 on: January 16, 2025, 08:02:24 AM »
That looks just like the bolt offered by KW.  It states for Purolator.  Visually, you can see a difference just in the head (where the gasket is supposed to be), that may or may not work.
I think it would be best to identify which type canister it is - whether correct or a donor unit from a different jeep.
Offline Eddie
Re: WANTED
« Reply #4 on: January 25, 2025, 10:54:06 AM »
Got one! Thanks for the help!
1953 CJ3B
1962 USN CJ3B
1971 Hurst Jeepster
1969 Mustang
