Author Topic: Hood to cowl  (Read 5777 times)
Offline 54-27329
Hood to cowl
« on: April 08, 2024, 07:22:13 PM »
1954 CJ-3B.  Assembling body parts on chassis. New tub and fenders, old hood and grill. Old hood too big, about 1 1/2 in wider than cowl. Question 1: would reproduction hood fit reproduction tub and old grill or just modify old hood?  Question 2: where the cowl angles in and bolts to fender, with the hood down, there's about a 2 inch gap between the hood bottom and body.  Is this normal?
Re: Hood to cowl
« Reply #1 on: April 09, 2024, 09:31:26 PM »
I've only owned an aftermarket hood and w/s frame.  It's my feeling that if all the body parts are aftermarket - from the same manufacturer, then they all fit together.  I sense that issues are seen during mixing/matching.
My w/s frame attachment arms weren't right - so I bent them. Its better now but I bribed a body shop into fixing my original that had screw holes everywhere in it.  The aftermarket hood was straight - no "oil canning" but the hinge wasn't right.  It caused the hood to sit too high at the cowl when attached.  I swapped out the rear hat channel/hinge of a bad original hood and was satisfied.  Until I ran across another original hood.
To your questions, there is a gap that runs all the way around the cowl - the hood should not sit down on the cowl.  I've noticed most hoods have a gap of about the same width all the way around - not noticeably wider on the sides.  There is also a gap between the side of the hood and top of the fenders - but 2 inches seems pretty wide.
Lawrence Wades' jeep:
https://cj3b.info/Photos/Owners/Wade/WadeBeachwoodTop.jpg
https://cj3b.info/Photos/Owners/Wade/WadeFoliageClose.JPG
https://cj3b.info/Photos/Owners/Wade/CurtisPhotos/HoodHinge.JPG
How close to the radiator guard contour is your hood?  Nearly flush?
Have you scoured through all the images to compare?
Can you post images?
« Last Edit: April 09, 2024, 09:39:22 PM by Rus Curtis »
Offline Mark W.
  • Chug A Lug
Re: Hood to cowl
« Reply #2 on: April 15, 2024, 03:05:18 PM »
Interesting my repop hood is tight enough on my original cowl that it actually digs into the paint on the sides
Chug A Lug
1948 CJ2A Tub and Title
1949 CJ3A Windshield
1957 CJ5 Frame and Springs
DIY Aluminum Hard top
Re: Hood to cowl
« Reply #3 on: April 15, 2024, 08:59:44 PM »
I've had original hoods that have flared out too far and some that pinch in.  I stand on the inside of the short side (on top of the hat channel) and bend.  I do this in the grass so as not to scratch.  Just a little at a time.  Then swap sides to keep it about even.
Offline 54-27329
Re: Hood to cowl
« Reply #4 on: April 23, 2024, 07:39:37 PM »
Will try to post pic.  Windshield was full of holes, had welder fill in all. Does someone have the dimensions for the wiper holes?
