i lost my brake lights on the Saturday ride in Gettysburg. so i'm trying to diag. my switch. the service manual is no help, " is its bad , replace it " i have both rear running lights, and rear turn signals. so i would say the bulbs are fine. i used a12volt test light, on the switch an no reading. with the brake pedal pressed down. i checked the wires that go to the switch ( i assume power goes just 1 side ) and if i put the meter between both wires i would get a reading. i got 12 volts from that test ,so it's fair to assume that the switch is bad ?
it's a pain to bleed the brakes, and just wanted to make sure i'm on the right path. any thoughts
thanks for the input
