Author Topic: F134 Quitting and Restarting  (Read 5096 times)
Offline Orlo
« on: September 08, 2023, 04:31:44 PM »
I had issues with my F134 in my 53 CJ3B:  It would die and start back up, and run for hours or minutes, and start right back up again.
It finally refused to start at all.  On a list somewhere about this problem, someone suggested checking the ignition switch.  I disconnected the wire from the switch to the coil, and did a jumper between the battery and the coil - started right up and ran!
I replaced the ignition switch and it has run fine ever since.
(I still carry the jumper in the toolbox)
Re: F134 Quitting and Restarting
« Reply #1 on: September 09, 2023, 05:16:12 PM »
Nice work!  Back when I drove as my primary, I had make-shift tools like your jumper wire.  They come in handy when you least expect it!
This problem you had is a reminder to check (sometimes recheck) since many parts we have now aren't as good as we remember.
Offline Orlo
« Reply #2 on: September 11, 2023, 09:15:41 PM »
Thank you!  I have trouble with imported coils and ignition switches for years.
Now if I can determine the source of the oil leak under the F134.....
