Author Topic: Sold  (Read 681 times)
Offline strobro32
Sold
« on: February 27, 2023, 03:53:41 AM »
High hood OEM F-134 Hurricane engine. I spent a year doing a frame-off restoration. New complete body from the Philippines. Frame was dustless stripped and repainted by Wally's Autobody in SAV. All new glass, new seals, new shackles, new shocks, new springs, new transmission overhaul, new transfer case overhaul, new steering column, case and linkages, new upgraded 12 volt electrical system with new gauges, new lights, new fuses, new switches, new wiring harness , new battery, new battery tray, new new voltage regulator, new motor mounts, upgraded truck brake system. new pads, new drums, new brake lines, new master cylinder, OEM wheels, new gas tank, new fuel lines and new fuel pump, new seat frames, new cushions, new seat covers and new aluminum radiator. The new body parts have completely been bed lined inside and out before reassembly. It's never been outside the garage unless sunny family drives. No rust and no Bondo. It has never been wet since restoration. Garage kept. I have the wipers/motors but never installed. Have all paperwork and receipts. Main seal now leaking, will need new motor. Currently starts and runs great. Can be driven onto a carrier.
If you have been looking for a great project that only needs a new motor, you will not find a better project jeep than this. SOLD
Matt
« Last Edit: March 04, 2023, 04:44:21 PM by strobro32 »
