Author Topic: T90C  (Read 4885 times)
Offline farm1810
T90C
« on: October 09, 2022, 08:44:52 PM »
Has anyone done the swap of parts to make your T90A into a T90C?  I am thinking the lower first gear would be nice, particularly when running taller tires and the 60 hp engine.  What has your experience been?
Offline OnlyOneDR
Re: T90C
« Reply #1 on: April 22, 2023, 09:42:56 PM »
There are a lot of folks that made the change on the ECJ5 forum.  There is a wider spread between gears so there is more peo of the line with the deeper first and second but the gaps are larger so you end up having to work a larger RPM band.  If you have an overdrive for great splitting then you will be fine.  I have the parts to do mine when that part of the build comes around.
1950 CJ-3A #37751 In Pieces
