Author Topic: Locker Issue Edit with Video  (Read 3998 times)
Offline trijjicon
« on: January 15, 2022, 09:52:45 AM »
This is a short video of what my 3A is doing with a recently installed lock right locker in the rear end... a Dana 41 with 10 spline. Are all flat fender owners using a lock right in a Dana 41 having to deal with this clunking?  Why can't I have a custom built shaft with a 30 spline that would work in a Dana 41? Why do I have to switch to a Dana 44, get another transfer case, have the 44 customized and rebuilt? That switch would run in the thousands of dollars, right? I've seen machinist build custom work for all kinds of applications. Why not this one? I'm not seeing or hearing this kind of noise/movement in other flat fenders that have lockers??
https://s.amsu.ng/FnASnbhVTrSN
Offline Mark W.
  • Chug A Lug
Re: Locker Issue Edit with Video
« Reply #1 on: January 15, 2022, 01:11:57 PM »
Why would a change in your rear axle have anything to do with the transfercase? I have an Eaton E Locker in my my Dana 44 30 spline flanged rear axle with the same everything as the D-41 used,
Chug A Lug
1948 CJ2A Tub and Title
1949 CJ3A Windshield
1957 CJ5 Frame and Springs
DIY Aluminum Hard top
Offline trijjicon
« Reply #2 on: January 16, 2022, 03:54:02 PM »
Was told the 41 has an offset mounting point for the transfer case, whereas the 44 is in the center.
« Reply #3 on: January 16, 2022, 04:25:45 PM »
Only a very few of the Jeep narrow track D44’s had the centered carriers from 1972-1975.
Yes the centered carrier axles require using a D20 in your CJ.
You can install a very common 19 spline D44 from any 1957-1970 CJ.
If you want a factory 30 spline offset carrier it must be from a 1970-1971 cj.
Those are rare rather expensive and very desirable.
That said installing the factory 30 spline is most likely over kill for most every L134 Jeep.
« Last Edit: January 16, 2022, 04:30:07 PM by oldtime »
Offline Mark W.
  • Chug A Lug
« Reply #4 on: January 16, 2022, 06:38:26 PM »
The exact reason I built a 1971 D-44 30 spline for my 2A powered by a warmed up 134L (making 140cuin etc.) I wanted to never worry about the rear axle again no matter what I did.
Chug A Lug
« Reply #5 on: January 16, 2022, 08:00:29 PM »
Sounds like it is "slipping" due to excessive clearance. Did you properly measure the clearance and shim the couplers? These old axles often require that additional shims be installed.
Offline trijjicon
« Reply #6 on: January 17, 2022, 01:41:31 PM »
R u guys saying that no one can custom build a rear shaft that would work with my transfer case, a 10 spline shaft, and a Dana 41? Do I need to re-shoot a video from inside the cab? This isn't a click click rachet thing, this is very loud ca-lunk ca-lunk even when backing up in a straight line. And is easily felt from within the cab. U can physically see the tire move laterally...more noticeable in a left turn. Not nearly as bad when turning right. I understand the locking/unlocking dynamic and foot off the gas in a turn. Even in a 44 (when engaged), it'll still do this? Just trying to get some clarity here.
Offline Mark W.
  • Chug A Lug
« Reply #7 on: January 17, 2022, 02:51:45 PM »
Aside from the comments that actually have nothing to do with your problem. I think what is being said is your rear end is set up wrong. If a tire/wheel can be seen moving in and out as you turn then you have serious backlash problems somewhere. As to having some sort of custom axle shaft made to work between a D-41 and some sort of Power loc track Loc selectable locker or what ever. I would assume with enough money you can get almost anything made. But why. For much less money you can either get your D-41 and the Power-Loc you have installed set up correctly or change out the rear end to a Pass side drop D-44 either tapered or a 30 spline flanged and get a different locker setup.
As I see this it has absolutely nothing to do with your transfercase.
« Last Edit: January 17, 2022, 02:53:29 PM by Mark W. »
Chug A Lug
Offline Bruce_W
« Reply #8 on: January 17, 2022, 04:09:28 PM »
I’m still trying to understand what the transfer has to do with it mysel. I think maybe we have a “terminology” problem here.
BW
Offline trijjicon
« Reply #9 on: January 19, 2022, 04:59:06 PM »
"Early Jeep rigs face a lot of problems when searching for a locker.
First is the 10 spline axle shafts, not a lot of options.
I have overcome this problem with custom made 30 spline shafts.
Next is offset rear axle.  Would be easy to swap in a later 30 spline Dana 44 but they are centered and that would require a different transfer case.
Anything is possible, just depends on how badly you need a locker and how much you want to spend.
I have done just about everything that can be done to early Jeep vehicles so you can get anything you want and your imagination is only limited to your budget".
I'd prefer not to mention names here but this quote is from a machinist with years of experience with flat fenders.
Offline tow hook
« Reply #10 on: January 20, 2022, 10:54:32 AM »
maybe you could get a tj rear dana 44 and cut it down so that it is off set vs centered that way it came ?. then just get one custom shaft for the short side, and remove the coil brackets. i've been looking for a off set 78 quadra trac rear. i saw one, it was over 1000$. you could do a full float kit, i believe that was mentioned already. i care to agree with the above that there could be more issues then the locker
