Author Topic: Marla Hooch - a CJ-V35/U  (Read 15628 times)
Offline Marla.the.V35
  • CJ-V35/U owner
    • Marla.the.V35 instagram
« on: October 04, 2021, 04:52:45 PM »
What a hitter!
While hiding out in Texas, I got the itch for another Flat Fender. I'd had one about 20 years prior when I was too young, broke, and naïve to keep it. Through borderline obsessive online admiring and searching, a mostly bone stock contender presented itself only a few hours drive away. After some back and forth with the owner, I decided to go check it out. I rented a U-haul truck and trailer and headed into the desert. I thought I was going to look at a CJ-3A, and indeed, the owner thought so too. Little did I know...
When I got it home and started really combing it, the data plate on the firewall lead me to Bob Westerman's site. Holy smokes. I'd inadvertently picked up a rare (1/1000 made), running, CJ-V35/U! I thought those headlight rings looked...different...this is where her name comes from. My wife looked at the rings and decided it looked like Marla Hooch from A League of Their Own. I get the jeep, she gets to name it ;)
Most of the "/U" parts went missing somewhere in time, but the hood, snorkel bracket, air cleaner canister, gas tank, brake master cylinder, correct military light switch, "rams-horn" frame hooks, pintle hitch, and a few other items are extant. The engine isn't original to the jeep, but is an L134 Go Devil. It runs, drives, and stops. It's got some add-ons like sears & roebuck locking hubs up front, a tow bar, a small winch, a Sears(?) half cab top, and 12v conversion. Like any good jeep, it came with some questionable stuff/problems. Just about every seal leaks, there was RTV sealant EVERYWHERE, the interior has been rhino lined, the suspension is a disaster or a disaster waiting to happen, the gauge cluster isn't original, something is bent somewhere (grill is definitely bent some and PO told me it had to be nudged into a mountain side due to brake failure), the steering had extreme slop, the fuel lines were "customized" at some point...and I'm sure there's more I don't know yet.
I really enjoyed my CJ-5 as a very young man, and then my first flat fender all those years ago (despite it being nothing near stock). I'm at a point in my life where I live comfortably enough to take on a project and do it as right as I can. My aim is to keep it running and in as close to its current, mostly stock condition as possible. This thread will serve as a chronicle of my ventures as I learn my way through doing it better this time around.
Thanks for stopping in!
-Jon
p.s. I should mention that I'm not the most mechanically inclined individual. I grew up without any kind of proper instruction, so I'm learning as I go. If just one person learns something from what I'm cataloging here, I will consider that a success.
« Last Edit: March 22, 2022, 10:34:10 PM by Marla.the.V35 »
'81 CJ-5 (RIP)
'48 FrankenFlatty (RIP)
'50 CJ-V35/U 10912
  • CJ-V35/U owner
Re: Marla Hooch - a CJV-35/U
« Reply #1 on: October 04, 2021, 07:05:12 PM »
Brake line S-tube replacement.
After some joy riding around the block, I noticed the inside of the passenger front tire covered with fluid. Investigation led me to the steel s-tube at the top of the drum where it connects the knuckle (via a bracket) to the flexible brake line. I ordered the parts (from a big supplier) and when it arrived, pulled the wheel/tire off (careful with those right and left hand lug nuts!) and installed the new s-tube. I wasn't that shocked when it didn't fit up perfectly, but, a little convincing by sliding a 1/2" brass drift in the curve and leveraging it into position got it just about right. I made sure to give it clearance so it wasn't rubbing anywhere. We then bled the brakes (using a compressed air system) and the leaks stopped!
'81 CJ-5 (RIP)
'50 CJ-V35/U 10912
« Reply #2 on: October 04, 2021, 08:21:32 PM »
I like your approach!!!
  • CJ-V35/U owner
« Reply #3 on: October 05, 2021, 04:17:59 AM »
Passenger tie rod end replacement and Ross Steering box rebuild.
The steering on this jeep was horrendous. There was about 1/4 turn of play in the steering wheel before the tires started moving and, for lack of a better way to describe it, felt really chunky in some spots.
Tie rod end:
So I started with the most obvious, easily visible issues while researching the steering box (more on that later).  I used my phone to record video of the linkages while I turned the steering wheel back and forth. Video revealed a lot of play in the passenger tie rod end, so I ordered from that same large supplier. I was actually quite pleased with the new rod end (which also came with a replacement clamp). The wheel was again removed, and the old tie rod end popped right out with minimal convincing. I've been very lucky with this jeep to not have to deal with rusty, stuck parts. The new rod end went into the tie rod, then into the knuckle. An alignment was performed by twisting the tie rod, which pushes either end out, or pulls them in, depending on the adjustment desired. I greased it with some NLGI No. 1 I'd found via Amazon.
Steering Box Rebuild:
After one of those previously mentioned joy rides, a large oily spot presented on the frame at the back of the drivers fender. Looking at the top of the box, I saw a grease zerk, and I pretty much knew the box would need rebuilding. To be sure though, I removed the fender, and opened the Ross Box. Only about a quarter of a gasket existed when I pulled the front cover. My assumptions were confirmed, it was slathered in grease. Two cans of brake clean later, and I could see two very large gouges in the worm gear. My heart sank. I won't lie, I went through a serious moment of "should I attempt to do the Saginaw conversion?" I even took a long, serious look at Herm's bolt on kit. In the end, I wanted the jeep to stay true, and any modification of that type would be a serious endeavor not only to complete (and I have no prior experience), but also to undo. It was time to rebuild the Ross Box.
I went to work collecting parts and watching videos. I admit to some naivete as I started with the big vendors first. Serendipitously, they were all out of re-pops, and I'm glad, because it probably saved me. Down the rabbit hole I went when I came to Pete DeBella, whom had a NOS worm shaft in stock. I snatched it up before I could even explain to my wife why that's important ;D I had him throw in the sector shaft kit as well. I picked up gasket and bearing kits, and everything else I thought I needed. I came across MetalShaper's youtube videos on the subject (can't recommend these enough). I picked up gasket makers, sealers, loc-tite...I've got a mini auto store going now...I purchased a 7/8" spiral flute hand reamer from Amazon. I removed the steering wheel...
Fortunately, my wheel came right off by hand. I've read horror stories about spraying for days and using pullers, but as previously mentioned, this jeep is in remarkable shape. I removed the three frame bolts, which have shims between the box and the frame. It's important to keep track of which shims were where, so I did this slowly and carefully. These are set from the factory and need to go back the same way, I'm told. The horn wire was cut, leaving enough room for re-connecting later. The drag link was disconnected using a Drag Link socket hollow ground bit (that I bought too big and ground the edges down some) from the pitman arm. With everything disconnected, I flipped the box over and pulled the whole assembly out through the floor (as is shown in the Kaiser Willys how-to video https://www.youtube.com/watch?v=GTEHyIJmnkE).
I broke down the box into its component parts. I kept EVERYTHING until I was sure I wouldn't need it (and even then, I plan on keeping everything but the worm as emergency spares).
The outer column sleeve was cleaned/sanded/primed/painted.
The front cover (the big one on the box) was removed and set aside, being careful to keep track of which hardware goes where. The brass (or in my case, copper) washers belong to the bottom two bolts.
The pitman arm was popped off of the sector shaft (again, came right off) and the sector shaft pulled out. The nubs on the sector shaft were worn enough for me to consider it unsalvageable.
The outer oil seal was popped out, and the sector shaft bushings were "pressed" out using a hammer and a deep socket just smaller than the OD of the bushing. In hindsight, I probably could've saved the sector shaft bushings (might've been able to leave them in?), but they got a little banged up on the way out. Might still be salvageable, but I'll investigate that later.
With the top cover removed and the the shims and hardware carefully cleaned and set aside, the worm shaft required a tiny bit of convincing to come out with races and ball bearings attached. This was all done very carefully so as not to scatter ball bearings all over the shop. There were snap rings outside the races, so everything held together until I could break them down, though I'm not sure that's standard, so be careful.
The horn wire tube was popped out by very carefully using a hammer on the tube to pop it forward.
I used an entire can of brake clean and half a roll of shop towels on the inside of the box to get the grease out.
The box and covers surfaces were wire brushed, cleaned, then masked and painted (rattle can primer and wheel paint).
With everything cleaned and all parts sourced, the box was reassembled.
First came the sector shaft bushings. I carefully pressed in the new outer (long) bushing, then attempted the inner (short) bushing.  As I've come to find is typical, the re-pop inner (short) sector shaft bushing would not stay in the box. I could slide it in and out with my finger. This would make it impossible to ream, so I went to Ebay, where I very luckily found a NOS bushing. It was as advertised. New, never used, required pressing into the box and needed reaming.
The scariest part was the reaming. As someone who has never done it before, this seemed like the most likely place for a screw up. I was concerned about the reamer not going through straight or wobbling/boring and taking off too much material. In the end, having the box in a vice so that the reamer was vertically oriented, going slow, and applying even turning force via a large tap wrench style tool assuaged any fears I had. Let the tool do the work!
When reaming was complete, an air compressor blew out the metal shavings (wear eye protection). I dry fitted the sector shaft. A perfect fit! Just enough room for oil, but not enough to be sloppy.
The horn wire tube was pressed back in (after a very small bead of right stuff was applied on the inside edge) and a LOT was applied to the outside.
I carefully reassembled the bearings on the NOS worm shaft. I ended up reusing the bearing cups/races (after some cleaning/polishing with emory cloth) with the new ball bearings from a kit (there were 11 per bearing). The new races just didn't sit right, and the originals weren't bad off, so I made the decision to keep them. At this point, the horn wire went through the worm, and was carefully threaded through the horn wire tube while putting the worm assembly in.
Getting the shims just right was a process! I followed Metalshapers videos and did a lot of assembly/disassembly/reassembly to get it right. I even went a step further and tested with one less 1/1000th and one extra, just to be sure I had the load on the inner bearings right. You should be able to turn it easily by hand, but there should be ZERO up and down movement! I took notes on paper of how many shims I used and their individual specs (thank goodness for micrometers!). I applied some aviation gasket maker on both sides of each shim once I was sure they were arranged to a correct tolerance before snugging the top cover down for good. Aviation gasket maker produces about 1/1000th thickness, so I did my best to account for that. I reused quite a few of the original shims since the repop kit only came with one thickness(I recall 1/7000th).
The front cover was put back on after applying some Permatex #2 on the gasket surfaces and anaerobic gasket maker applied to the two lower bolts' threads before sending them in with the copper washers . I let the gasket makers and sealants cure for 24 hours, then went overboard and applied some Right Stuff around all potential leak spots (hornwire tube, upper cover, front cover), just to be sure. I haven't seen a leak yet.
I sourced a 1/8" NPT plug from amazon for the fill hole (good riddance, grease zerk!).
While I had the drag link down, I decided to clean up the parts. I kept track of which end was which by punching an arrow into the drag link near the front denoting "forward" (this is important). I cleaned the springs and spacers, and polished all of the cups. I went ahead and polished the bell crank ball (which looked to be in pretty good shape). I bought a repop kit, but used only the dust covers and one nut. For some reason, the old nut wouldn't turn down enough to fit the cotter pin with the new pitman arm I'd bought (the old ball was worn out) but the new one did, since the grooves were cut deeper.
I put the outer column clamp over the worm and installed the assembly back in the way it came out, but without the outer column sleeve. This gave me a little more wiggle room and made reassembly a little easier. I slid the outer column sleeve down from the top ('inside' the jeep) and cinched the clamp with the bolt and sleeve groove correctly oriented (clamp bolt up, sleeve groove down).
The column was reattached to the dash via the brackets using the original welt.
The Pitman arm was put on loosely with a large grade 8 washer,  lock washer,  and 5/8" nut.
The drag link was reattached at both ends.
Steering wheel was put back on.
I filled the box with the new oil.
With the vehicle on jackstands, I backed out the the axle wheel stops and tested the steering lock to lock.
The sector tension screw was set so that the wheel drags just a little through center. Plan on noodling on this a bit and readjusting after test drives.
After some test drives,  the pitman arm was adjusted one tooth to the right,  then put back on,  loc-tite red 271 applied,  and tightened down until it couldn't be anymore.
The axle stops were adjusted to hit just before the box hit full lock.
I put the fender back on.
I'd like to say that everything went as smoothly as I'm portraying it here,  but truthfully,  there was way more back and forth.  I had to drain the box while chasing leaks, apply sealants and gasket makers repeatedly and wait for them to cure, and had to re-disassemble parts that had been loc-tited together...I thought I had the shims right,  but after mulling it and thinking on it for a day,  knew it couldn't be. So I pulled it apart until it was.  I got very frustrated when some of the 'new' parts didn't want to fit right,  or the shims got bent while cleaning them (some of those are paper thin!)  What I've written up here is the most ideal process and assumes no issues encountered.  I hope it helps someone to avoid the hassles and mistakes I ran into.
Rebuilding the box was quite an undertaking, even with all of the videos, reading material, and questions I asked over various channels. There are some things I would recommend for anyone who plans to take it on:
  • Take your time! Don't rush any of the rebuild in your want to get driving again.
  • Don't throw away any of your original parts until you can inspect them and be sure they need replacing. Much of the old stuff is still likely in good shape, is the best fit, and is of superior quality.
  • Before you put the front cover on, center the sector shaft on the worm, then use a punch or paint marker to make reference points for their alignment. Once you've got the cover on and the box full of lube, this will be near impossible. I cannot over stress the importance of this.
  • Reuse your old shims if possible. New shims come in one size, which might take you farther away from the desired load than when you started. Seal these with Permatex Aviation Form-A-Gasket (#80019). For good measure, I used some Perm right stuff around the outside as well.
  • I used Permatex No. 2 sealant between the front cover gasket and metal parts to prevent leaks (ask me about learning this the hard way)
  • If you're not doing a body off resto, don't fill the box and do the sector shaft tension screw until the assembly is back in the jeep.
  • Make sure all of your gasket sealants and gasket makers are cured before adding lube.
  • Add some gasket sealer around any bolts that go through the box into oil. And be sure the copper or brass washers are on the two bottom most bolts on the front cover.
« Last Edit: July 13, 2022, 05:25:09 PM by Marla.the.V35 »
'81 CJ-5 (RIP)
'50 CJ-V35/U 10912
Offline OnlyOneDR
« Reply #4 on: October 12, 2021, 06:08:22 PM »
Looks good so far!
1950 CJ-3A #37751 In Pieces
  • CJ-V35/U owner
« Reply #5 on: October 19, 2021, 07:13:00 PM »
Suspension work begins (1/?)
With the steering stuff managed, it was time to start in on the suspension work.
I knew from the get-go that the springs were in terrible shape. 3 of them have an add-a-leaf at the bottom, one may have two at the top. The clips are floating around at best, but about half are missing and the packs are 'fanning' as a result. They're sagging on the right side (which is curious as it's opposite the normal lean...though the PO may have swapped them to even them out). I did some cursory research after purchasing the jeep a few months back and weighed the pros and cons of Crown, Omix, Walcks, custom built packs, and even considered re-arching these or finding a set on ebay. In the end, I decided Walcks was the best product for my intentions, has a better reputation than it's nearest competitors, and was within my price point. I also felt a little better getting an entire kit as opposed to building one out myself. We started work by getting her up on jackstands, then supporting the pumpkin with a floor jack. The shackles were loosened up (easier said than done...) and the pivot eye bolt removed. Some 'convincing' with a mini-sledge got things going and the shackle popped out of the bracket still attached to the spring. The u-bolts were removed and the entire spring pack came free. The shackles are toast (replacements came with the kit :) ). Some of the bushing threads are worn smooth.
Some time back, I discovered the shackle brackets at the rear were booger welded together to repair them from something terrible. Through deeper investigation, it's clear the Previous Owner got into something really rough...either bounced it really hard, dropped it into a hole, or??? I ordered 4 new shackle brackets from Walcks and plan to just swap them all. I did not opt for rivets, so these will be attached with Grade 8 hardware and the bolts cut down and painted black. When everything is tight, we'll weld the brackets to the frame and touch up paint. I also ordered 4 pivot eye bolt brackets (where the springs attach directly to the frame). I noticed the one at the spring we removed was a little bit oval and figured it best to just be sure it's done right. The shackle bracket was removed, piece by piece, by cutting the vertical parts with a cutting wheel, cutting/grinding the rivet heads off, then chiseling (carefully) to break the welds and "walk" the remaining piece off. A punch and mallet were used to drive out what was left of the rivets. Once the bracket was off, the surface rust was cleaned while grinding the welds off and getting the area flush. I primed and painted.
The rear upper shock mounts are in really terrible shape. The drivers side has been re-pinned and booger welded such that the welds are cutting into the shock bushing, the passenger side has had it's entire outer vertical piece torn off, a square nut booger welded in, and a pin run through and also booger welded. Of the lower shock plates that I've seen, the pins appear bent and may or may not have original welds. It looks like a cascade of poor trail fixes that persisted....So, now it's time for those things to be replaced. These parts have all been ordered, but, I couldn't quickly locate an upper set that was true to stock with the cotter-pin. They're threaded, so I opted to get the lower plates threaded as well. I know it's not exactly stock, but from what I've seen of the hassle the cotter pin type are, I'm hoping I can get the shocks on there without too much fuss with the threaded system.
After 6 hours of work, we'd removed one spring and one shackle bracket lol. That's some work! The kit came with shocks, but they're a hideous color of blue, so, while waiting for the paint on the frame to dry, figured I'd rough them up with some sandpaper and paint them black with a high temp paint.
I'm looking forward to getting the entire system replaced, and hoping it takes less than a month. I expect the passenger side pack to be an equal amount of work, and I have no idea what awaits us getting the upper shock mounts off and the replacements in.
Definitely more to come!
« Last Edit: October 20, 2021, 04:26:42 PM by Marla.the.V35 »
'81 CJ-5 (RIP)
'50 CJ-V35/U 10912
« Reply #6 on: October 20, 2021, 08:42:28 AM »
Maybe you should name it... Ben Boogered.  Wouldn't it be interesting to know the "history and stories behind during the PO"...
You're doing great work to bring her back to "proper presentation" and enjoyment, and SAFETY.  Thanks for sharing your process and "findings" along the way.
  • CJ-V35/U owner
« Reply #7 on: October 20, 2021, 01:48:15 PM »
"Maybe you should name it... Ben Boogered."
LOL!
I would LOVE to know how this happened to the rear suspension. I know this was his hunting rig and that he used the winch and some snatch blocks/tree limbs to get carcasses into the back, but I can't imagine even the largest bull would do this...
Thank you for the kind words. Save the Willys!
'81 CJ-5 (RIP)
'50 CJ-V35/U 10912
Offline tow hook
Steering box refresh
« Reply #8 on: February 12, 2022, 03:09:57 PM »
Thanks for the post on the box rebuild. We’ll I got my steering box bushings from k.w.  The shaft had some scoring on both front an rear.  Glad I got 2 new bushings. the new rear bushing should be ok fit wise,  The front bushing slides right through. Im gonna have wait till Monday to solve this, and hope the next one fits.  Was hoped to have it wrapped up on one day.
Update both bushings are not good. They both measure .99  old bushing are 1.0 front slides right through rear bushing pushed in, but could be moved. Doubt it wouldn’t spin with the shaft in place. Found a nod bushing on e bay, but it has the new part number listed in the add ?!  Him what to do ? O mix Ada also has bushings, looking into those to nite.
« Last Edit: February 12, 2022, 05:55:40 PM by tow hook »
Offline tow hook
« Reply #9 on: February 12, 2022, 03:14:48 PM »
My shocks were also blue, black rust oleum oil based took care of that. The foam brush made them look amazing.
Offline Bruce_W
« Reply #10 on: February 13, 2022, 01:30:06 PM »
  “  O mix Ada also has bushings, looking into those to nite.”
If you bought from Kaiser-Willys you probabl already have Omix-ADA.
  Ive always bought my bushings from Walck’s 4WD or Ron Fitzpatrick Jeep Parts. Never had that trouble.
BW
  • CJ-V35/U owner
« Reply #11 on: February 13, 2022, 01:44:20 PM »
I got mine from DeBella and the inner one didn't fit (tho I got NOS worm from him). I ended up getting a NOS bushing from quarter ton military on ebay.  Good luck!
'81 CJ-5 (RIP)
'50 CJ-V35/U 10912
  • CJ-V35/U owner
« Reply #12 on: February 14, 2022, 03:53:14 AM »
Suspension work 2/?
Welp, my hopes to have this wrapped up in less than a month clearly didn't happen LOL. Anyways, I figure it's time for an update on the suspension work. The drivers rear is now complete, after some lesson learning...
In the previous update, I mentioned we cut the old brackets off, which left the rivets still in the frame. Since I was planning to replace them with Grade 8 hardware (in hindsight, I wish I'd grabbed frame bolts), these needed to be popped out. To do so, we used a punch and a series of hammers of varying size. This turned my arms to hamburger, and still didn't solve the rivet buried deep in the crossmember above the axle (or I didn't have a long enough punch!). My brother-in-law (whom is helping with the work, is mechanically inclined, and works at a local metal shop), suggested some carbide burrs. I purchased a double set of 1/4" burrs (tree, cone, barrel, and rounded head), which fit up into that spot with the die grinder. We ground the heads off, then used the cone burr to grind out the "carcass". I wish I could tell you I was prepared for the torque these produce when they're unhappy...but I surely wasn't. I also tried a drill with a metal bit, but after accidentally angling through the frame some, decided that was a lesser option.  Finally, with all the rivets out, and all the old welds ground flush, I painted the frame, then bolted on the brackets. This took some measuring and aligning of each to the frame. I then ground the paint at the seams and each bracket was welded on. The spring brackets are welded on both sides, but access to the rear of the upper shock mounts was basically impossible with the body on, so we only did the front side and put some faith in the grade 8s holding them down. Each nut was tacked to the bolt to insure nothing was going to back out. During this time, we accidentally pierced a brake line! More on that later...
Speaking of the upper shock mounts....these are re-pops. I bought them knowing they are manufactured for a later jeep and not at all correct to the V-35. They have a threaded post that accepts a nylock nut as opposed to a smooth post/cotter pin as is original. But, the lower shock plates I could find quickly were threaded, and so for consistency, and also because it doesn't require a special tool to compress the shock bushing and slip the pin through, I went ahead with them and consider them an upgrade. I'm sure no one is shocked when I say that the holes didn't line up. So, using those same burrs and a bench vice, I went to work boring the holes out some. It's at this point I feel inclined to tell people to wear face and eye protection! While I was grinding one of the holes out, the tip caught an edge, twisted, banged around and basically exploded. Thank goodness I was wearing eye-pro and a face mask! Also, this wasn't the first thing that exploded in proximity to my face. I also grenaded a grinding wheel. WEAR YOUR FACE SHIELDS!
Shrapnel aside, everything went pretty well. There was some muscling to get the spring eye bolt into place and the rear shackle in, but everything is together on the drivers rear now. We learned a lot, and going forward I'm hoping the passenger side goes much faster. I count my lucky stars I ordered this suspension kit over last summer, since it seems parts are hard to come by now.
Now to the passenger side!
« Last Edit: March 21, 2022, 10:19:45 PM by Marla.the.V35 »
'81 CJ-5 (RIP)
'50 CJ-V35/U 10912
Offline tow hook
« Reply #13 on: February 15, 2022, 10:54:06 AM »
i saw a bushing on ebay, they were using the crown part number, and saying that it was nos. it was the quarter ton military guy. wasn't sure how i felt on buying it....  so monday i called kw i told mark what was up, and the bushings were .099 vs 1.00 he found a set and said they were 1.009 so they are in the mail. hope to have a update thurs or fri
  • CJ-V35/U owner
« Reply #14 on: February 15, 2022, 01:29:48 PM »
That's great! I hope you get the right stuff and are back on the road soon! I will say, I've ordered a few things from QTM and haven't had an issue yet. That said, the brake line is sitting in a box in the shop yet to be opened....
'81 CJ-5 (RIP)
'50 CJ-V35/U 10912
