Author Topic: CJ3B - Herm Steering Kit  (Read 3034 times)
Ron
  • Guest
« on: September 26, 2021, 11:18:46 PM »
Good evening everyone,
I have been planning on using Herm’s Ford Reverse Steering kit on my CJ3B for awhile.  I got to the point of installing it today and found out that with the stock cross member, it will not be far enough forward so that the drag link lines up correctly.
Has anyone else used Herm’s kit on a 3B?
If I have to modify the cross member, I may just go with a manual Saginaw steering box.
Thoughts
RVSwisher
Re: CJ3B - Herm Steering Kit
« Reply #1 on: September 27, 2021, 12:58:54 PM »
Thoughts
RVSwisher
Ron,
With a quick search, I did find this post on Early CJ5 Forum talking specifically about this kit:
http://www.earlycj5.com/xf_cj5/index.php?threads/herms-power-steering.127681/
I haven't checked the links embedded but it seems there may be issues with interference.  I also noted that this may be a Saginaw but in reverse.
Offline farm1810
« Reply #2 on: June 18, 2022, 08:23:08 AM »
I am responding to an older post on this subject, but chose to follow up on this one instead of creating a new one.  I purchased Herm's kit recognizing that there could be interference issues.  I actually cut out the cross member by the radiator and moved it.  Then realized the problem with the motor mount location as well (stock engine).  I believe this was designed for a CJ5 with V6 engine, not for a Jeep with a L or F head engine.  I finally abandoned the effort and move to an out front Saginaw arrangement.
Offline duffer
  • Just old
« Reply #3 on: June 23, 2022, 10:45:38 PM »
I'm another that just can't see any advantage of Herm's kit.  The Saginaw installation has no doubt been completed thousands of times on flatties, is both straight forward and well documented.
48 2A, 49 3A, 51 Wagon, 55 3B, 57 FC 150, 57 Wagon, 60 FC 170, 68 CJ 5, 2012 JKUR
John, Bozeman, MT
Offline Marla.the.V35
  • CJ-V35/U owner
    • Marla.the.V35 instagram
« Reply #4 on: June 24, 2022, 01:24:03 AM »
Coming from someone who considered it for a hot second, it's mostly appearances. All the benefits of a better steering setup, without affecting the outward look of the flattie. Also, if I recall correctly, it's touted as a mostly bolt-on system, so the appeal is there for someone who doesn't weld. (We all know how that goes with these old flatties though, nothing is that easy haha)
When it came time to pick a direction for my own steering, I decided to rebuild my steering box and replaced a few worn components. With quality parts, correct lubricants, and proper adjustments, it feels way tighter than I could've ever imagined it would, and I didn't have to do any modifications. Guys have got some horror stories about the ol' stock steering system, but don't believe 'em. When it's correctly maintained and setup to spec, it feels good and tight.
« Last Edit: June 24, 2022, 01:26:54 AM by Marla.the.V35 »
'81 CJ-5 (RIP)
'48 FrankenFlatty (RIP)
'50 CJ-V35/U 10912
Offline tow hook
« Reply #5 on: July 08, 2022, 12:04:13 PM »
 i got the kit as well, i did not use it either. with out removing any parts like a cross member/ or the engine plate that goes to the motor mounts . it's not bolt in with out some cutting. i rebuilt my ross box, wish it was better. but it's better then before thank heavens
