Author Topic: spartan turn signal pilot light ground  (Read 2572 times)
Offline tow hook
« on: September 15, 2021, 02:02:49 PM »
my indicator  bulb isn't working on the turn signal unit, it says that it grounds thought the housing.... but were ?
 i've removed paint on the column and the column clamp, no luck. i cleaned up ( aka sanded ) the metal the the bulb holders goes to. and sanded the arm below it. the jeep has a new walcks harness, and the spartan unit came from mid west willys any help would be great. thx
p.s. i'm not a wiring kinda guy
https://www.mywillyspics.com/image/jEQ02
https://www.mywillyspics.com/image/jtZPg
https://www.mywillyspics.com/image/jtWO6
Re: spartan turn signal pilot light ground
« Reply #1 on: September 15, 2021, 04:43:40 PM »
If it were me, I'd approach this like an "unkown" tail light.  Using jumper cables (with either contact tips or alligator clips on the ends), I'd test the bulb - straight off the battery.  Then I'd insert the bulb and using a known ground connected directly to the socket and to a bolt or screw, test the light when the switch is on.
Keep moving down-stream on the ground until it stops working and you should find the bad ground. This can also be done with a multi-meter.
I'd done all this on my turn signals and found it to be a bad ground.  On my turn signal, I ended up running another wire (for ground) from inside the case all the way down the wiring harness to a good connection under the dash.
« Last Edit: September 15, 2021, 04:46:15 PM by Rus Curtis »
Offline tow hook
« Reply #2 on: September 20, 2021, 11:20:44 AM »
Offline tow hook
« Reply #3 on: September 24, 2021, 02:51:49 PM »
 i got some tips how to use a multi meter.  so i tested the power wire going up the column, tested good. so i ran a ground wire from the the screw ( in the rear ) that holds the guts in place down the column to a ground and bam she blinks !  yee ha.. now to finish that speedo
« Reply #4 on: September 24, 2021, 05:33:48 PM »
Nice!
Offline tow hook
« Reply #5 on: October 03, 2021, 02:15:47 PM »
Yep , the small items are getting narrowed down. She isn’t pretty but hope to be driving it soon
