Author Topic: Signal Stat 900  (Read 1581 times)
Offline Spacecrab
Signal Stat 900
« on: July 31, 2021, 08:27:06 AM »
Hi guys,
Recently the pilot light on my 3b's Signal Stat 900 died
Has anyone repaired one of those before and is it easy?
If it's a burnt bulb, can they be found these days?
I quite like these units and if the revs are up I can't here the ticking so the flashing light comes in handy
Any opinions welcome
Restoring a 1954 CJ3b
Re: Signal Stat 900
« Reply #1 on: July 31, 2021, 11:53:55 AM »
I ended up having to open mine to add a ground wire.  That bulb is under the top half of the case.   It's been a while since I've been inside but I believe the cover over the bulb just lifts up (I recall having to carefully keep everything in place when adding that ground as stuff could get loose.  I can't remember if it's part of the arm too).  Since they can burn out, they have to be accessible.
Right out of the manual:
"Replace pilot bulb with #51 for 6 volt, #53 for 12 volt, or #356 for 24 volt service."
Below is an image inside mine (where I was adding a yellow ground).  The blue wire is the pilot light.
Offline Spacecrab
Re: Signal Stat 900
« Reply #2 on: August 03, 2021, 08:03:18 AM »
Thanks Rus, your a great help as always
I'll have a stab at it this weekend  :)
