Author Topic: Odd fuel starvation in new Carter carburetor  (Read 2347 times)
Offline Goggleeye
« on: July 04, 2021, 02:42:31 AM »
I installed one of the new Carter carbs. Just putting around at low rpms and zipping around the farm everything runs better than ever. But  After running down the road for a while - 5-10 minutes or more - at higher engine speeds, it runs out of fuel. I have a clear in- line fuel filter right before the carb and I can see there’s no fuel.  If I disconnect the fuel line at the carb and immediately reconnect it, fuel rushes in, it starts right up and I can go down the road another 5 minutes. It’s almost like a vapor lock that prevents fuel delivery. Any suggestions?
Offline PercyUK
Re: Odd fuel starvation in new Carter carburetor
« Reply #1 on: July 04, 2021, 03:11:52 AM »
Hi, take the fuel cap off and see if it resolves it. If it does then it is a faulty vent in the cap.
Offline Goggleeye
« Reply #2 on: July 04, 2021, 08:00:06 AM »
Originally thought that may be the problem but it’s not. Makes no difference.
Offline PercyUK
« Reply #3 on: July 04, 2021, 09:03:44 AM »
It could be that your float valve is sticking closed, this would prevent fuel entering and then when you take the hose off the pressure drops and the valve opens again? The system is simple so if not its the fuel pump then it could be  a blocked filter or line somewhere. The obstruction could be falling away when you relieve the pressure by pulling the hose off and then gets dragged back in when you set off.?...... maybe
« Reply #4 on: July 04, 2021, 09:40:43 AM »
Quote from: Goggleeye
I added "quotes" as posts were hidden.  I agree with Percy that it may involve the pump - or somewhere else in the delivery.  Do you have a glass bowl pump where you can see the level?  How's the tank (debris)?
To me, your last sentence was the most important.  You disconnect the line at the carb.  You don't indicate the back pressure (tank, pump, fuel delivery line) pushing fuel out - indicating a carb block or stuck needle.  Upon re-connection, you get immediate flow (not an expert on vapor lock-but it seems that's resolved with removing the heat source, i.e. repositioning the fuel line).
Have you tried swapping out the filter (even though it shows empty)?  What it sounds like you're describing is fuel delivery at low demand but starving at higher demand.  The pump should keep the carb full.
There could be some trash in the line that higher rpms/vibrations are affecting flow. Any maintenance on the fuel lines themselves?  Have you disconnected and blown lines clean?
« Reply #5 on: July 04, 2021, 05:40:59 PM »
There's a whole lot of information missing from this. We don't know what motor it is, or carburetor, or fuel pump. The problem could very well be in rubber lines. Old rubber lines develop cracks. Those cracks will suck air at the higher RPMs. Resulting in fuel starvation because the carburetor does not burn air by itself. Please, more information.
« Reply #6 on: July 11, 2021, 05:26:03 PM »
Pictures of the installation would help greatly.
Offline Goggleeye
« Reply #7 on: August 04, 2021, 06:03:51 PM »
Sorry, life got crazy busy.  Thanks for all the suggestions. I Think the fuel line was picking up too much heat from the exhaust and boiling/vaporizing the fuel.  Haven’t had much time to mess with it but a crude heat shield seemed to help.
