Author Topic: engine dept.  (Read 629 times)
Offline msk
engine dept.
« on: April 22, 2021, 03:24:39 PM »
I need some help in trouble shooting a back fire issue. My cj3b willys runs great at idle and low rpm while it was in the garage. Took her for the first road test. As soon as I give her more gas to increase power (slight incline) it starts back firing. Noise is so loud I'm concerned I will blow her new exhaust system. Any suggestions?
Re: engine dept.
« Reply #1 on: April 22, 2021, 05:33:05 PM »
Welcomed msk.
We know nothing about the service history of your engine.
There is a small multitude of conditions that effect your trouble.
Therefore you need to follow the factory tune up sequence.
If you have a proper service manual then follow the sequence as printed.
This should get you started.....
« Last Edit: April 22, 2021, 05:44:24 PM by oldtime »
Re: engine dept.
« Reply #2 on: April 22, 2021, 05:41:15 PM »
Okay, my bad.  I'll take the hit - probably should have been clearer.  May need to get an administrator's help in moving this down to the Engine section.
This is where I was thinking first too.  Tune up status and what you have.  As we get deeper we'll know more and can help more.
Re: engine dept.
« Reply #3 on: April 22, 2021, 05:47:50 PM »
