Author Topic: Mystified  (Read 12544 times)
Offline Mytwojeeps2020
Mystified
« on: February 26, 2021, 06:19:53 PM »
Wow, I keep finding weird Jeep issues-and I’ve been around them for 50 years.
Today, I went to change the oil on my new-to-me 61’ CJ5. It’s been in the family since early December.  The oil is clean, but I thought, what the heck, change it anyway.
I don’t know why I didn’t notice it before, but the inlet/outlet holes on the oil canister had been plugged by the PO!
I checked the oil for cleanliness before I bought it.
Why in heck would anyone plug the canister holes? I have all his old receipts, so he wasn’t afraid to spend money on it.
<insert grumpy face here>
Current Jeep: 1961 CJ5 “Olaf”
Re: Mystified
« Reply #1 on: February 26, 2021, 07:30:38 PM »
That may have been the previous owners approach to try to improve the oil pressure.
Re: Mystified
« Reply #2 on: February 26, 2021, 09:12:11 PM »
It would also cut down on oil filter expenses.....
Re: Mystified
« Reply #3 on: February 27, 2021, 12:07:05 AM »
I never thought I’d ask this question, but, in your opinion, is it safe to run this thing without an oil filter? I know that filters were an option on many of the earlier engines.
My first impulse is to reinstall the lines. Joy...
Re: Mystified
« Reply #4 on: February 27, 2021, 06:00:55 AM »
Filters are cheap insurance against failure.
Re: Mystified
« Reply #5 on: February 27, 2021, 08:04:17 AM »
What holes ?
The inlet hole on the stand pipe that’s inside the canister ?
The outlet hole at the base of the canister ?
How were they plugged ?
Was there a filtering element inside the canister ?
« Last Edit: February 27, 2021, 08:06:53 AM by oldtime »
Re: Mystified
« Reply #6 on: February 27, 2021, 01:11:41 PM »
Oldtime: My replies are in bold below. Thanks for your review!
What holes ? The holes that are plugged are the inlet and outlet plugs going into/from the oil filter canister.  Also, a brass (I think its brass) plug has been inserted into the port near the timing chain; I can’t tell what type of plug was used beneath the fuel filter - I can feel it (I think), but I can’t see it.
The inlet hole on the stand pipe that’s inside the canister ?  The standpipe is still in the canister, but like I said, it’s been plugged off from below the canister.
How were they plugged ?  They appear to be brass plugs wrapped with Teflon tape.
Was there a filtering element inside the canister ?  Yes. The canister had an old filter in it and both it and the canister were full of old (dirty) oil
PS: I’ve replaced the hose from the filter to the hole under the fuel pump before, but that was with a single-action fuel pump that I didn’t have to remove to get to the hole.  I’m now working with a duel-action pump, and can’t see below it. Before I start tinkering with the fuel pump, can anyone post pics of what/where the crankcase oil plug is? Much appreciated!
« Last Edit: February 27, 2021, 01:14:43 PM by Mytwojeeps2020 »
Re: Mystified
« Reply #7 on: February 27, 2021, 02:41:47 PM »
Note:  I had to log out and see the comments.  Copied below for anyone else that can't see (so they don't have to log out, yada, yada, yada):
Quote from: Mytwojeeps2020
Quote from: scoutpilot
AGREED!  Even a partial filter system would be beneficial.  The timing gears wouldn't complain about the extra oil bath either!
Quote from: oldtime
What holes ?
Quote from: oldtime on Today at 08:04:17 AM
Okay.  Here are some easy pics to locate and post from the 3B Page:
Oil "Inlet" next to the radiator connection running behind the vacuum "T"
Oil "Inlet" line as it curves behind the pump
Another view of oil "Inlet" where it attaches to galley and runs up behind pump and towards cannister:
Hope this helps.
« Last Edit: February 27, 2021, 02:45:11 PM by Rus Curtis »
Re: Mystified
« Reply #8 on: February 27, 2021, 04:54:09 PM »
Rus, is that the oil port just below the fuel pump?
Re: Mystified
« Reply #9 on: February 27, 2021, 05:14:39 PM »
Yes!
After posting I found this.  Shows the galley and path - to include that "Inlet" from below the pump up to the filter
https://cj3b.info/Tech/OilPressure.html
Re: Mystified
« Reply #10 on: February 27, 2021, 06:01:16 PM »
Excellent, Rus, thanks!
You’ve given me yet another chance to avoid expensive mechanics!
(Not to mention learning good things in the process!)
« Last Edit: February 27, 2021, 06:02:54 PM by Mytwojeeps2020 »
Re: Mystified
« Reply #11 on: February 27, 2021, 06:42:10 PM »
It appears to me that perhaps the hoses got old, cracked and blew out.
The hose ports were then plugged instead of finding the correct replacement hoses ???
Offline Bruce_W
Re: Mystified
« Reply #12 on: February 27, 2021, 08:36:57 PM »
Or someone fell prey to the old wives’ tale about the oil filter causing reduced oil pressure.
BW
Re: Mystified
« Reply #13 on: February 27, 2021, 09:15:56 PM »
Quote from: Bruce_W
BW
Some weird things have been done in the past.  IF you plan to replace the hoses to make the canister function again, I'm also sharing a couple of threads specific to my issues with this. Your jeep is a 1961 CJ5.  I'm assuming an F-head engine.  Look under the cannister to see if there's a 45* fitting.   In the threads below, I show a long hose from Walck's that didn't work with my fitting.  I later learned that his hose was designed to work without the fitting (straight connection from cannister to timing cover).
https://www.tapatalk.com/groups/cj3b_bulletin_board/viewtopic.php?p=44894#p44894
https://www.tapatalk.com/groups/cj3b_bulletin_board/oil-filter-inlet-tube-t2801.html
Re: Mystified
« Reply #14 on: February 28, 2021, 05:27:27 PM »
Will, do. Thanks! I’ll report back when I get it done. The parts were ordered this morning.
