Author Topic: '54 3B parts for sale  (Read 1352 times)
Offline bbelongia
« on: December 16, 2020, 04:34:50 PM »
I have various parts from a '54 3b.  I am using the frame and some various other trim parts, the rest is up for grabs to a good home.  This 3b was used hard, it appears to have mowed brush with a pull behind mower, it had a band of steel welded around the entire body for brush deflection.  The frame is tore in 4 places, and the body tells the same story, it's beat up.  All body parts are not usable unless you found a good section to cut out and weld into your project.  Tub has a metric ton of Bondo applied at some point.  No seats or tail gate.  Maybe the windshield frame, grille, and hood could be saved... maybe.  It has the entire drive line from engine to T-case, the engine is frozen, transmission and t-case are free.  Axles appear to be intact and complete.  Leaf springs look to have add-a-leafs, I have never seen packs that thick on a Jeep.  Also have clutch linkage, pedals, PTO, spring hangers, 3 stock wheels, ect.  Front bumper full of holes, the rear bumper is a miracle of angle iron and welding rod.  I'd rather see it go as a collection vs. piece by piece.  To be clear, this is for parts/rebuild, was not running when I picked it up.  I am 1 hr north of Dallas.  PM/email/text/smoke signal with questions.  469-500-4312
Offline bbelongia
Re: '54 3B parts for sale
« Reply #1 on: December 29, 2020, 10:49:29 AM »
Just an update, I probably won't be using most of the frame accessories like engine mounts and other attach points for stock springs/linkages/ect.
Also for fun a few pics of the previous owner frame fix..
Offline Spacecrab
« Reply #2 on: March 12, 2021, 08:02:16 AM »
Hi there, I'd be interested in the accelerator linkage, any e brake parts and possibly the carb if your willing to sell them stand alone.
International shipping would be needed however,
Thank you
Restoring a 1954 CJ3b
