Author Topic: How to put a new steering wheel on?  (Read 2722 times)
Offline ChrisW_3B
« on: June 19, 2020, 03:34:43 PM »
I purchased a puller and successfully(?) removed my old steering wheel.  Now I am trying to get the new wheel [1] on, I can't get it on enough to start threading the nut.  Before I start doing something stupid, is there any wisdom on this?
Chris
[1] https://walcks4wd.com/Steering-Wheel-Early-MB-1946-1962-CJ-DJ3A-FC-Models_p_1222.html
Re: How to put a new steering wheel on?
« Reply #1 on: June 19, 2020, 07:53:45 PM »
Hi Chris,
I purchased the same steering wheel for a 3A.  I couldn't get it to seat far enough to install the horn button.  I cleaned up the steering shaft splines with a varied set of mini- files from Harbor Freight.  This helped quite a bit, but I still had to use a block of wood and a mini-sledge hammer to get it on enough to set the button.
« Reply #2 on: June 19, 2020, 10:40:04 PM »
Don't forget some anti-seize in case you need to take it off again.
Offline ChrisW_3B
« Reply #3 on: June 20, 2020, 11:34:48 AM »
Thanks.  I put grease on it.  But maybe I'll clean it up, and switch to anti-seize.
Offline ChrisW_3B
« Reply #4 on: June 22, 2020, 08:41:13 AM »
I pulled the wheel off, rotated it so a different spoke pointed down.  Drove a couple miles to a friends, as I left his house the wheel settled on and exposed 3-4 threads worth of the shaft.  Tightened it down, nut is on a bit over half way.  Progress.
