Author Topic: Correct 12 volt battery  (Read 2354 times)
« on: April 11, 2020, 10:49:36 PM »
Still working on my 1964 CJ3B restoration. I am looking for a period correct 12 volt battery. The hold-down bracket and J-bolts are missing on my jeep, but I see that Walck's has a reproduction hold-down bracket that matches the one shown in the photos of the 1963 "Showroom Original" CJ3B on the CJ3B page. Walck says the I.D. of the bracket is 10-7/16". The modern batteries that I have looked at all have molded brackets on the end for a carrying strap that would interfere with the hold-down bracket. I guess I need to take the hold-down bracket to the battery store and see what they can match it to?  Thoughts?  Thanks!
From Walck's On-line catalog:
From the CJ3B page:
« Last Edit: April 11, 2020, 10:53:33 PM by Chuck W. »
Re: Correct 12 volt battery
« Reply #1 on: April 11, 2020, 11:04:44 PM »
Yeah it’s probably best to take your hold down bracket with you when buying a battery.
At times I have trimmed plastic off from the sides of batteries.
I usually opt for a group 24 or 24F.
If you want a lower profile you might like the group 34 or the 34R.
« Reply #2 on: April 11, 2020, 11:09:36 PM »
Chuck,
That's exactly what I did:  Took the hold down to the store.  I wanted the older style and didn't have one.  Found an after-market and had a shop cut it and expand it to fit the 12V case I wanted and to ensure I had clearance around the positive post.
As you can see, not all batteries will have the carry strap.  Different brands do different things (sometimes within same brand different battery case).  I used L bolts to secure to the tray.
http://www.batteryweb.com/bci.cfm
This helped me narrow down the size I wanted (but I still did the trial fit).
« Reply #3 on: April 12, 2020, 02:47:28 PM »
Thanks for the thoughts. The battery that was in the jeep when I bought it is too small and does not fit the tray. There was no hold-down, so I built something to get by, plus it is a modern battery with the plastic strap handle.  It would be great to find a battery that looks period correct for 1964, with individual cell caps and no handles. I, too, have cut the plastic handles off of a battery to make it fit, and that may be the route I have to go. I am going to have to find a better place to look other than the local auto parts stores.
I did find this that might be the answer:
Offline Mark W.
  • Chug A Lug
« Reply #4 on: April 12, 2020, 04:08:47 PM »
Just do a google search for Vintage look car Battery
« Last Edit: April 12, 2020, 04:11:38 PM by Mark W. »
Chug A Lug
1948 CJ2A Tub and Title
1949 CJ3A Windshield
1957 CJ5 Frame and Springs
DIY Aluminum Hard top
« Last Edit: April 12, 2020, 10:32:32 PM by Chuck W. »
