Author Topic: Steering knuckle capacity?  (Read 4226 times)
« on: March 31, 2020, 01:21:56 PM »
Need to buy some lube and wondering the capacity of the knuckles.  Anybody know for sure?  Searched the manual and I can't find the answer.  Thank you.
Re: Steering knuckle capacity?
« Reply #1 on: March 31, 2020, 02:15:43 PM »
Tom,
There's a reference to this on the CJ2A Forum:
https://www.thecj2apage.com/forums/steering-knuckle-capacity_topic4364_post30862.html?KW=knuckle+capacity#30862
This will help get you close.  I suspect having a bit extra would help if a top-off or seal failure caused you to need some "right now"
« Reply #2 on: March 31, 2020, 04:34:35 PM »
Thanks, Rus.  All I can glean from that thread is "about a half pint ea.", but I have to say that doesn't seem like enough.  It looks more like a pint to me.
This would be nice to know, I wonder why they didn't print the capacity in the Universal manual.
No problem, I'll buy a quart and should be covered.
Offline binthere
« Reply #3 on: March 31, 2020, 05:24:32 PM »
I just do the same as I do with the tranny and transfer case--fill with gear oil till it starts running out of the fill hole.
« Reply #4 on: March 31, 2020, 08:22:39 PM »
Tom,
I think that's pretty much how everyone does it; add until it's full.  Depending on your knuckle type, you may be able to buy small pouches of CV joint lube at the parts store.  I have Spicer joints so I use 140wt.
« Reply #5 on: March 31, 2020, 08:59:34 PM »
Rus, does the 140 wt. leak out at all?  I'm thinking "00" grease.  It's thicker but still flows nicely.  I'm putting some Spicer axles in so really just need it to lube the king pin bearings.
« Reply #6 on: March 31, 2020, 10:37:15 PM »
I have not yet had leaking issues.  I've read other posts where owners have reported the same.  I did pack my kingpin bearings, just like the wheel bearings, to hopefully keep the upper from sitting dry when the axle isn't splashing.  I don't have any experience on the spicers in this location but I would be concerned about the thicker grease flowing into the needle bearings.
What I can confirm is that if your jeep knuckles were packed at some point with #2 grease (and allowed to run for an extended time), a Bendix will wear and come apart.
Offline MikeP
« Reply #7 on: March 31, 2020, 10:38:19 PM »
1950 willys cj3a
« Reply #8 on: March 31, 2020, 10:43:44 PM »
Mike,
That link took me to their #2 grease.  You will find this is too thick and will stick to the walls of the knuckle and won't penetrate the axle joint at all.  If you're planning to use  this to pack your kingpin bearings, then you, me and a few others are all doing the same thing.  I think this will work well in the kingpin bearings.
Offline MikeP
« Reply #9 on: April 01, 2020, 06:42:18 PM »
my bad i got it mixed up i meant to use this https://www.amazon.com/Premier-Quality-Products-57-376792-Champion/dp/B071QZL5DQ for the knuckles and steering box and the other grease is for everything else that needs grease
1950 willys cj3a
« Reply #10 on: April 01, 2020, 07:56:33 PM »
Thanks, Mike.  That's the stuff I had in mind for both knuckles and steering box.  Sounds like we're on the same page.  I guess if it's no good, at least there will be two of us! ;)
« Reply #11 on: April 01, 2020, 08:43:14 PM »
That looks like good stuff.  I like the squirt cap on the top.
Offline MikeP
« Reply #12 on: April 01, 2020, 08:50:32 PM »
i do have a bottle of it that i recently bought for my steering box i havnt opened it yet but i could open it and do a small test with pics
1950 willys cj3a
Offline edsajdak
« Reply #13 on: June 01, 2020, 02:25:47 PM »
JOHN DEERE CORN HEAD GREASE. Maybe $2.50 a tube, fill until it comes out the fill hole. Holds 3/4 of a tube when bone dry.
