Author Topic: 3a engine supports problems  (Read 1521 times)
Offline Rab
« on: March 01, 2020, 10:24:23 AM »
Hello all
I’m in the process of putting together 3a power train and got everything
in. My problem is the steel engine mounts the PO had cut them off from the frame
I bought a set but turns out they weren’t for a 3a engine
Do any of you have a set that’s 100% for a  3a engine?
Nothing quite like old iron to work with
Re: 3a engine supports problems
« Reply #1 on: March 01, 2020, 03:46:34 PM »
Where you located ?
I probably have a set that I can cut off from one of my 3B frames.
I'll take a look.
Offline Rab
« Reply #2 on: March 01, 2020, 08:52:31 PM »
Woodbury Tennessee about 70 miles south east of Nashville zip code is 37190
« Reply #3 on: March 03, 2020, 10:30:23 AM »
This post belongs in the FS WTB category.
I have at least one frame that I plan to remove the original F-134 engine mounts (exact same as CJ3A mounts) to swap in a Dauntless.
So I'll be pulling off at least 1 good set and I could use a good set of Dauntless frame brackets if anyone has a set.
I'll send you a message.
