Author Topic: 1950 CJ3A ROCK CRAWLER BUILD  (Read 4258 times)
Anthony Scott
  • Guest
« on: December 27, 2019, 11:27:40 PM »
I know some will feel my build is blasphemy but a lot of the original parts are long gone or damaged by time and neglect. I could have restored it with new and used parts but I want the look of the old style with some of the comforts of modern components. I'm 54 so I figure I will get maybe 25 years of use out of it before handing it down to one of my grandchildren.
I know it is an ambitious build but I am confident that I can do it. I am doing all of the build myself.
I have owned my 1950 CJ3A for approximately 20 years. It had a 1955 Chevy 283 when I bought it. I drove it when I first bought it but I ran out of money at the time and it sat for years. Now that I am older and have more time, I decided to build it the way I wanted. I decided to build it into a road worthy rock crawler. It will be a resto mod. First I changed out the 33 inch tires for 35's. I am boxing the frame. I have removed the leaf springs and built and upper triangulated 4 link rear suspension using TJ 3.5 inch lift coil springs. I bought a Dana 44 full floater kit from Herm. I also bought a locker, 30 spline axles and disc brake conversion/w parking brakes. I have trussed the rear axle in preparation for the upgrades.
The front axle will be replaced with a Dana 44 front axle from a newer vehicle. I will put coil over shocks and a 3 link in the front with high steer, disc brakes and power steering.
I already swapped out the weak T90 for a T18 4 speed that I had taken out of a 1969 Ford F100 I once owned. The Dana 18 transfer case had been rebuilt just before I parked it years ago after it self destructed on a trip.
I will be installing a Chevy 350 engine with vortec heads from Summit racing. As of now I am planning on installing an Edelbrock fuel injection system.
The body mounts have been cut from the frame and welded back 3.75 inches higher. I am using CJ5 body mount bushings to clear the transmission and engine. The tub has a few rust spots. I am going to cut them out and tig weld new metal in. The front fenders were garbage so I will be building aluminum flat fenders. It will be painted a spruce green with metal flake. The interior and underside of the tub will be black rhino liner. I will be building a custom roll cage.
The lighting will all be upgraded to LED. I have moved and built beefed up cross members. I will be building a custom aluminum fuel tank under the rear.
Offline smrmedic
Re: 1950 CJ3A ROCK CRAWLER BUILD
« Reply #1 on: December 31, 2019, 04:52:45 AM »
I was rebuilding my rear axle only to find out that it was a Dana 41 instead of the Dana 44 I thought it had. According to the information on the dana 44 tech site it should have been a dana 44.
" The Dana 44 was introduced in the CJ line on the CJ-3A starting with serial number #37549 (late '50). Earlier CJ-2As and CJ3As did not use the Dana 44."
My serial number is "43951" but it has a dana 41. The D41 uses a smaller ring gear that won't fit the newer D44 30 spline locker. The locker is the same width as the D41 carrier from what I can see. I also had to swap my yoke from a 10 spline to a 26 spline to fit the new pinion. The full floater kit I purchased from Herm uses 30 spline axle shafts. I purchased the powerlock with the full floater kit to match the axles. I also purchased the disc brake conversion kit with it as a package deal. With all of that combined with my axle truss should make for a much stronger set up.
The housing cover gasket is different too. Luckily I hadn't opened the lube locker gasket package yet so I am able to return it on Amazon. Hopefully I can return the 10 spline yoke as well.
I should have looked at the axle closer to begin with instead of just using what I read.
Hopefully this information can help others. I'll post more information as I go along.
SMRMEDIC is my screen name. I wasn't able to use it in my first post because it hadn't been approved yet, in case anyone noticed the difference from my first post.
« Reply #2 on: December 31, 2019, 11:12:13 AM »
D41 has larger diameter ring gear than a D44 not smaller.
You cannot put a D44 Powr Lok differential into a D41 carrier.
You will have to locate a D44 housing if you plan to install anything other than a lunchbox locker.
Offline smrmedic
« Reply #3 on: December 31, 2019, 10:31:20 PM »
The inner diameter of my ring gear is smaller than the powerlock carrier. It won't fit onto the carrier. The bolt holes have a smaller radius from the center as well. T he powerlock carrier seems to fit the case. I checked the new carrier bearings and the carrier width in the case. Maybe the case is a 44 but the shape looks like a 41 in the pictures and the 44 gasket doesn't fit.
Offline smrmedic
« Reply #4 on: December 31, 2019, 10:32:58 PM »
Here is a case picture.
Offline smrmedic
« Reply #5 on: December 31, 2019, 10:36:56 PM »
I'm new to this axle so I appreciate any help and information.
Thanks.
Offline smrmedic
« Reply #6 on: December 31, 2019, 11:00:32 PM »
I just checked the carrier in the case again. I see what you meant about the locker not fitting. The locker body itself is too wide. It hits the bearing mount on one side. I guess it is time to look for a 44 for the rear. I have been thinking about going a little wider anyways. Thanks for the information. I really appreciate it.
Offline smrmedic
« Reply #7 on: December 31, 2019, 11:56:44 PM »
I found a dana 44 out of a 69" cj5 so I'm going to pick it up tomorrow. From what I have read it is the same width as the 41 so all of my parts should work. Thanks for the Information Oldtime.
« Reply #8 on: January 02, 2020, 11:58:57 AM »
Yes a 1969 Jeep narrow track Dana 44 is a very good replacement axle assembly.
And it will accept a 19 spline D44 Powr Lok differential case.
FYI the differential case assembly fits into the carrier section of the axle assembly.
Offline smrmedic
« Reply #9 on: January 03, 2020, 12:32:16 AM »
Thanks Oldtime. This is the kit I bought from Herm to put in the axle.
"CJ rear disc brake kit + D44 Full floater kit + New 30 spline D44 PowerLock"
I also got a new yoke and new 5.38 gear set. I haven't set up gears before so I bought 2 bearing sets with shims and seals so I can ream out one set to use for set up bearings. It was cheaper to buy the whole set than the individual bearings.
The dana 44 axle came with a dana 27 with disc brakes in a package deal. Both have 4.88 gear sets. I'm not using the 27 though. I'm going to find a dana 44 for the front also since I am running 35" tires. I'm planning on using an OX locker for the front. I haven't decided for sure what type yet, manual, electric or air. I need to study more. I want to have a selectable locker for the front.
