Author Topic: Replacing pilot bushing  (Read 2206 times)
Offline Vincent
  • 1953 WO CJ3a
« on: November 22, 2019, 12:13:35 PM »
I’ve removed the pilot bushing from the flywheel. The flywheel will be resurfaced. The new bushing does not fit on the transmission pinion shaft. I assume it needs to be reamed. On page 119 of the mechanics manual, it says the inner diameter of the  clutch shaft bushing is .628”. This equates to 5/8. So do I ream the bushing to 5/8? And should I do it before or after installing in the flywheel?
Vincent S.
vschleg@yahoo.com
Offline RichardS
Re: Replacing pilot bushing
« Reply #1 on: November 22, 2019, 12:41:16 PM »
after it's installed in the flywheel
