Author Topic: A1674 Distributor bracket  (Read 1649 times)
Offline Andrew
« on: November 13, 2019, 01:37:04 PM »
For a IAD4008 distributor, I need the clamp style bracket  that has one bolt into the motor block and a second bolt that clamps the bracket around the distributor body where it slides into the block. Willys part # A1674. Willy called it an 'advance arm' (used to lock the distributor rotation after setting the dwell). I have also heard it referred to as the distributor mounting bracket. It apparently was used on other auto-lite Wllys distributors too.  Anyone have one needing a CJ3A to call home?  Thank you
Re: A1674 Distributor bracket
« Reply #1 on: November 14, 2019, 10:26:20 AM »
Where you located ?
I need a  correct 3A title
Offline Andrew
« Reply #2 on: November 15, 2019, 06:16:00 PM »
 My CJ3A is a 1949 that I am restoring, with good title, but I do not have any 'extra" title. I am in western Pennsylvaia. Still looking for the A1674 distributor clamp.
« Reply #3 on: November 15, 2019, 07:43:20 PM »
Andrew,
If one doesn't materialize, there's always Harry Sheets :  http://www.midwestwillys.com/
I would guess he's probably got a stack of them.
