I'm really the one who's been hoping to have the Willys Group Index implemented.
3 main reasons:
1) It was and still remains as the original foremat by Willys Overland, Willys Motors and Kaiser Jeep Corporation to categorize each and every part or assembly.
Implementing it will never be outdated and those with books at home can very readily reference that same material.
By the way... excepting the Military Technical Manuals; I have every Mechanics Manual, Universal Service Manual, Universal Parts List and Universal Parts Catalog that was ever published including the supplemental publications.
(!945 through 1973)
2) It's mainly an aid towards quick locating for any specific subject matter.
In essence it eliminates need for a search engine.
3) It is fully effective regardless of your Jeeps model or vintage.
It gets all Jeep owners regardless of Jeep model or year onto the same page.
We could have done it on the 3B forum but sadly it meant going through all old post and having them categorized.
The Willys Group index has evolved and changed over the years but I have thoroughly scanned all years and recreated the Complete Willy Group index in its most complete form.
Also Modifications from standard and or optional could be added to the Willys Group index.
The only downside I see is that it does not cover anything like New Members, General Information (what kind of oil is best etc.) nor does it cover Buy Sell postings, Bantam Trailers, etc.
WILLYS GROUP INDEX
GROUP 10 ENGINE
10.01 Engine
10.02 Cylinder Block
10.02A Cylinder Head
10.03 Crankshaft
10.04 Crankshaft Bearings
10.05 Connecting Rods and Bearings
10.06 Pistons and Pins
10.07 Piston Rings
10.08 Valves. Valve Guides and Springs
10.09 Valve Tappets
10.09A Valve Rocker Arms and Push Rods
10.10 Valve Spring Cover - Exhaust
10.10A Rocker Arm Cover - Inlet Valve
10.11 Camshaft and Timing Gears
10.12 Gear Cover
10.13 Oil Pump
10.14 Oil Pan
10.15 Oil Float
10.16 Oil Filler Tube + Level Indicator
10.16A Oil Filter
10.17 Oil Distribution System
10.18 Crankcase Ventilator System
10.19 Manifold
10.21 Flywheel and Ring Gear
10.22 Flywheel Housing
10.23 Engine Mounting
GROUP 11 CLUTCH
11.01 Clutch Assembly
11.02 Clutch Control Parts
11.03 Clutch Pedal
GROUP 12 FUEL SYSTEM
12.01 Fuel Tank
12.02 Fuel Gauges
12.03 Fuel Lines
12.03C Fuel Filter
12.04 Carburetor
12.05 Air Cleaner - Oil Bath
12.05A Air Cleaner - Dry Type
12.06 Choke Control
12.07 Throttle Control
12.08 Accelerator and Linkage
12.09 Fuel Pump
GROUP 13 EXHAUST SYSTEM
13.01 Exhaust System
GROUP 14 COOLING SYSTEM
14.01 Radiator
14.02 Radiator Hose
14.03 Radiator Guard
14.04 Water Pump
14.05 Fan, Fan Pulley and Fan Belt
14.06 Thermostat
GROUP 15 ELECTRICAL
15.01 Generator
15.01A Alternator
15.02 Starting Motor
15.03 Distributor
15.04 Voltage Regulator
15.05 Ignition Coil and Wiring
15.06 Spark Plugs and Cables
15.07 Body and Chassis Wiring
15.08 Sealed Beam Units and Lamps
15.09 Headlights
15.09A Parking Lights
15.09B Tail and Stop Lights
15.09E Tell-Tale Light
15.09G Directional Signal Lights
15.11 Instrument Panel Light
15.12 Foot Dimmer Switch
15.12A Lighting Switch
15.13 Starting Switch
15.13A Ignition Switch
15.14 Stop Light Switch
15.17 Horn and Bracket
15.17A Horn Button and Wiring
15.18 Battery Support
15.18A Battery Cables
15.22 Trailer Electrical Units
GROUP 16 INSTRUMENTS
16.01 Instruments
16.01 Ammeter
16.02 Heat Indicator
16.03A Oil Gauge
16.04 Speedometer
GROUP 17 TRANSMISSION
17.01 Transmission
17.02 Main Drive Gear
17.03 Main Shaft and Gears
17.04 Reverse Idler Gear
17.05 Countershaft and Gears
17.06 Gearshift
17.07 Remote Control
17.09 Speedometer Gears
GROUP 18 TRANSFER CASE
18.01 Transfer Case Assembly
18.02 Transfer Case
18.03 Drive Gear
18.04 Gears, Shafts and Bearings
18.05 Idler Gear, Shaft and Bearings
18.06 Shift Lever
18.07 Shift Rods
18.08 Transfer Case Mounting
GROUP 19 PROPELLER SHAFTS
19.01 Propeller Shafts
19.02 Universal Joints
GROUP 20 FRONT AXLE
20.01 Front Axle
20.01A Steering Stabilizer
20.02 Housing
20.03 Differential
20.04 Pinion Bearings
20.05 Universal Joints
20.06 Steering Knuckle and Spindle
20.07 King Pin and Drive Flange
GROUP 21 REAR AXLE
21.01 Rear Axle
21.02 Housing
21.03 Differential
21.04 Pinion Bearings
21.05 Axle Shafts
GROUP 23 STEERING
23.01 Tie Rod and Bell Crank
23.01A Steering Connecting Rod
23.02 Steering Gear Assembly
GROUP 24 BRAKE SYSTEMS
24.01 Hand Brake
24.02 Wheel Brake - Manual Adjust
24.02A Wheel Brake - Self Adjusting
24.03 Wheel Brake, Shoes and Linings
24.04 Brake Mechanism - Manual Adjust
24.04A Brake Mechanism - Self Adjusting
24 .05 Cylinder, Wheel - Single System
24.05A Cylinder, Wheel - Split System
24 .06 Cylinder, Master - Single System
24.06A Cylinder, Master - Split System
24.07 Brake Tubes - Hydraulic
24 .07A Brake Tubes - Split System
24 .08 Pedal - Brake
24.09 Brake Booster
GROUP 25 WHEELS
25.01 Wheel and Attaching Parts
25.02 Hubs, Drums and Hub Caps
25.03 Bearings, Seals + Attaching Parts
GROUP 26 FRAME
26.01 Frame
26.03 Pintle Hook
26.04 Draw Bar
GROUP 27 SPRINGS
27.01 Front Springs
27.02 Rear Springs
27.03 Spring Attaching Parts
27.04 Shock Absorbers
GROUP 28 BUMPERS
28.01 Bumper Front
28.03 License Tag Bracket
GROUP 29 FENDERS
29.01 Front Fenders
29.04 Body Steps
GROUP 30 HOOD
30.01 Hood
GROUP 31 BODY
31.01 Body Assembly
31.02 Hood Hold-Down Attaching Parts
31.03 Windshield
31.03A Windshield Wiper
31.03B Rear View Mirror ( Outside )
31.03C Sun Visor
31.04 Cowl, Dash + Instrument Panel
31.06 Body Sides
31.07 Seats
31.07A Drivers Seat
31.07B Front Passenger Seat
31.07F Rear Passenger Seat
31.08 Rear Body
31.09 Floor and Underbody
31.10 Tailgate
31.13 Spare Wheel Carrier
31.14 Plates, Seals and Covers
GROUP 32 TOOLS
32.01 Tools
32.02 Tool Box
GROUP 33 PAINT
33 .01 Paint
GROUP 35 SPECIAL EQUIPMENT + ACCESSORIES
35.02A Power Take-Off - Complete Kit
35.02B Power Take-Off - Control Unit
35.02C Power Take-Off - Rear Unit
35.02D Power Take-Off - Propeller Shaft
35.03 Power Take-Off - Pulley Drive
35.05 Hydraulic Pump and Implement Lift
35.08 Governor, Belt Driven
35.11A Body Steps
35.12 Chaff Screen and Brush Guard
35.13 Bumper Bar Weight
35.17 Full Body Top Kit
35.18 Heater ( Harrison )
35.21 Heater and Defroster
35.21A Heater and Defroster - Fresh Air
35.23A Reflex Reflector
35.24 Rear View Mirror ( Inside )
35.26A Propeller Shaft Guard
35.27A Starting Crank
35.29 Fuel Tank Cap - Lock On Type
35.31 Dual Tail and Stop Lights
35.33 Spare Wheel Lock
35.34 Dual Windshield Wiper
35.35 Fuel Tank Cap - Lock-on Type
35.40 Fuel Filter
35.40A Water Filter
35.43 Spot Light
35.44 Back-up Light
35.45A Fog Lights
35.46 Under Hood Compartment Light
35.47 Fire Extinguisher
35.51 Windshield Washer - Automatic
35.54 Miscellaneous Accessories
35.56 Insect Screen
35.59 Directional Signal Lights
35.86 Enclosure
35.86A Enclosure, Hinged + Sliding Doors
35.86B Enclosure, Rear Door
35.93 Safety Strap
35.99 Exhaust Emission Control System
35.100 Roll Bar Kit
35.102 Roll Bar Padding[/b]
I'd really like to know what all of you think about this possibility.
