Author Topic: Generator battery wire routing  (Read 4647 times)
« on: July 19, 2013, 08:24:50 AM »
Last night when I put the 6 volt alternator on, I noticed how the wire labeled battery was run. I had to take the clamp off in order to make the wire reach the alternator. So, before I forget how it was done, here it is.
There is a clamp behind the air cleaner and then it goes over to the voltage regulator.
