Author Topic: What is this skid plate piece for?  (Read 1858 times)
Offline BobM
« on: May 04, 2019, 09:29:47 AM »
I am getting things back together. After I reinstalled the e-Brake asy, I remembered this piece that was bolted to the skid plate under the drum. I can't find any reference to it. It appears to protect the drum? It bolts to the skid plate with 4 carriage bolts. The plate is cut for the bolts. It seems like there is something missing in the back. There are two holes that appear to have a purpose. Any ideas?
Re: What is this skid plate piece for?
« Reply #1 on: May 04, 2019, 10:48:59 AM »
That may be a piece of the "Propeller Shaft Guard" accessory.� There are images of the pieces, I'll have to search around to see if I can find them.
Added:
https://www.thecj2apage.com/forums/grass-shields_topic11075.html?KW=propeller+shaft+guard
« Last Edit: May 04, 2019, 11:13:11 AM by Rus_Curtis »
Offline BobM
« Reply #2 on: May 05, 2019, 08:31:51 AM »
Oh wow that's it! I also have the dealer installed air bags. This was a Jeep used for farming. It only had 43,000 miles on it. It was beat as bad as it gets however! I will take the plate out. It is the only piece I have of the shroud you have pointed out. I guess it and the air bags will go up as garage "wall art".
Thanks a lot!
Offline JeffH
  • Ol skool jeeper
« Reply #3 on: July 30, 2019, 08:25:16 AM »
It is for the grass shield!
 Here's a thread with a pic of it installed and the rubber flex mount bolted to it.
https://www.thecj2apage.com/forums/grass-shields_topic11075.html�
Need to install bolts with rounded head down so they dont hang up on rocks too!
« Last Edit: July 30, 2019, 08:35:02 AM by jeeper50 »
Red '48 CJ2a Chevy 283, SM 420 trans, Brennans disc kit all corners Lockright in D41, Powerloc in D25, 3.15 Terra Low in D18, Belleview winch soon, original Jackman rims! Beachwood Canvas trailrun top
