Author Topic: Serial Number database-please add your jeep.  (Read 18588 times)
« on: December 18, 2012, 12:08:45 PM »
Hi guys...
Pascal, QuebecJeep here on the 3A page, is doing a super job of updating our old serial number database you can find on the front page of our site.. If you click on the Roberto Flores picture or the 3A PAGE right next to it, it will take you to the home page, where there is a button top and center for the serial number list. The main use for this is for research, and for guys who are attempting to find the correct engine number range for their own 3A.
If you don't mind, the more jeeps we have on the list the more accurate guesses can be made for the correct numbers on a jeep, so please add any 3A jeeps you own.
Here is a cut and paste from Pascal's post on the newbie forum.
 If you want to be listed in our serial number database (http://cj3apage.com/Serial%20Numbers.htm) , please send me your information by email (pascal.lavoie.pl@gmail.com) or PM me.(QuebecJeep)
 Information needed:
Year
Serial Number
Engine Serial Number
Details
Owner Name
Location
Email
 You have a picture! Great! Send it as well. �
 It should be in jpg format with a size less than 1 Meg.
 It would be great if you can name it like this:
 example: 1950-CJ3A-Pascal-Lavoie-56908.jpg
 Thanks
We appreciate your taking time to add your own jeep and the appropriate numbers and picture. �:)
« Last Edit: December 18, 2012, 12:10:47 PM by F_Bill »
Offline Bill_D
Re: Serial Number database-please add your jeep.
« Reply #1 on: November 17, 2018, 05:30:46 PM »
1949
12621
3J13080
Has been restored in the past. Great job.
William F. Dawson
Colorado Springs, Colorado
wfdawson@comcast.net
« Last Edit: November 17, 2018, 05:34:02 PM by Bill_D »
1949 CJ3A
1950 M38
1952 M38
1963 CJ5
1980 CJ5
2003 TJ Rubicon
“I never met a Willy’s I didn’t like.”
« Reply #2 on: November 18, 2018, 03:03:38 PM »
Hi Bill,
Just a recommendation.  Send all your information directly to Pascal's email.
He is our only active administrator, but he doesn't check in here everyday.  I believe he checks his email regularly.
« Reply #3 on: November 21, 2018, 07:59:52 PM »
Hi, yeah! I�m not very present lately. And i have a lot of cj3a database registration pending in my email. Sorry about it. I�ll try to do it.
Offline Daveg64
  • save a tree...eat a beaver.
« Reply #4 on: January 09, 2019, 11:07:06 PM »
1951
451-gb1 19902
no engine #
running project
monterey,ca
dave gouker
badfxdwg@hotmail.com
51' CJ3A,73'CJ5,06'F250 and a few Harleys.
Offline johnrb3b
    • Jeeps and stuff
« Reply #5 on: January 25, 2019, 10:31:41 AM »
Yes
At the moment Pascal (Quebec Jeep) is the only one of us Admins who knows how to access the database. Since Bill had to bow out, we're running on Pascal's know-how.
Many thanks to you Pascal.
Offline MikeP
« Reply #6 on: September 21, 2019, 03:52:35 PM »
pm sent with info
1950 willys cj3a
Offline williams3b54
« Reply #7 on: November 20, 2019, 12:28:13 PM »
Here is my 1954 cj3b info;
1954 F-Head cj3b (Highhood)
Serial no. :454GB2  and 31396
Engine no. IT54994
Most of the running gear is the original: 19 spline rear axles for Limited slip from 1969 CJ5, 11" drum brakes from Wagoneer, tilt steering wheel from Chevy truck ( shortened) on board air "VIAIR", Warn winch (TABOR 9,000# ) front dana 25 dif. open, Model 18 transfer case with Husky O.D., full roll cag (custom) high back Chevy Cavalier seats, 33"X 12.5 tires X 15"on Aluminum Ultra wheels, custom made bikini top, Hydraulic clutch linkage( Custom) overhead brake and clutch pedal assy from 1975 Cherokee,12V converted, electric two speed windshield wipers from 1971 CJ5, custom rear tire and luggage rack with lunch table, 'Mariner' blue paint.
Spokane Washington
cjwilliams1940@gmail.com
Offline steves
« Reply #8 on: September 12, 2020, 06:28:46 PM »
I would like to add the serial number of my 1951 CJ3A to the database, but I'm not sure if I know the correct entry.  There is a serial number plate in the engine compartment, installed in the correct location, but the number does not fit with any of the numbers in the database.  The last 6 digits are also copied in the engine block serial number, .
Serial number plate on firewall:  451-GB1 3J101484
Number stamped on engine block:  3J101484
The number from the plate on the firewall has been used as the VIN on the title.  The title is clean and clear.  The vehicle was first registered in California in July 1951, and the title shows that the list price was $421 (?!).  It is now in Arizona.
« Last Edit: September 12, 2020, 06:45:26 PM by steves »
« Reply #9 on: September 12, 2020, 09:34:51 PM »
In 1951 the state of California used the engine serial number as the "VIN" for the title. This was very common in many states in the 'good old days'. Since then someone has replaced the original Patent Plate with a reproduction patent plate that was stamped to match the title.
Offline steves
« Reply #10 on: September 14, 2020, 04:52:51 PM »
That does seem like the most reasonable explanation.  I couldn't find any on-line vendors that sell that type of Patent Plate, but someone apparently does (or did).  So, it appears that there is no way to find the original, correct, serial number.
« Reply #11 on: September 14, 2020, 05:15:25 PM »
Are the frames not stamped like the 3B's?
« Reply #12 on: September 14, 2020, 08:03:20 PM »
The frame stamping did not begin until 1953. I have never seen a CJ-3A frame that was stamped. I suspect the very first CJ-3Bs didn't have frame stamps either. More data is needed to determine the exact starting point of the stampings.
Offline OnlyOneDR
« Reply #13 on: October 07, 2020, 03:32:09 PM »
I noticed that the serial number page does not get updated.  I sent information to Pascal a long time ago for mine but I am sure he has many other things directing efforts elsewhere.  Not sure if the site admins would be open to some outside help but I used to administer the site my club had (before we closed it down a couple years ago due to dwindling funds).  If someone wanted help with getting this database page updated I would be glad to take up the charge.  I looked at the code for the page and it is really simple; it looks like the back end of the site (not the forum) would be pretty easy to administrate and update.
1950 CJ-3A #37751 In Pieces
