Author Topic: Electric fuel pump  (Read 3369 times)
Electric fuel pump
« on: June 03, 2018, 05:20:41 PM »
Thinking about the fall color tour this year.  In doing some reading it sounds like vapor lock is a big concern with the guys that go there.  One of the common reccomendations was to install an electric fuel pump.  So some questions for you guys:
Does that sound like a cure for vapor lock?
If so what pump would you install?  What flow rate?
Would you remove the existing fuel pump and plumb direct to the carb? How about a pressure regulator, needed?
Could you install the e pump up stream of the mechanical pump, leaving the mech. Pump installed, kind of like a charge pump?
Appreciate any insight.
Gun
Re: Electric fuel pump
« Reply #1 on: June 03, 2018, 06:43:29 PM »
I installed mine directly below the tank right in the line from the tank.� I ran flexible fuel line from the top of the tank (M38 tank) and then couple your steel line to the pump or to the rubber line on the discharge side.� The instructions with the pump will tell you exactly how to do it.� �I put a little push/pull switch on the dash next to my light switch in an existing hole.� Then you can grab power from your light switch, the key switch, or wherever you want.� I think the brand is just a cheapie Mr. Gasket or something, but it works great.�
I only use it if the jeep has been sitting for a while like in my garage in the winter, or at the FCT say when we shut down from running hard for a few minutes to the point where the fuel has the chance to get really hot from sitting.� I'll just flip on the pump for a few seconds until I'm up and running.�
I have also insulated the fuel lines and routed them such that they no longer get very hot and that has helped a lot.� Are you 6v or 12v?� It will matter when you buy your pump.
edit:� Also, they come in different pressure ratings.� You'll want the lowest pressure you can find, say 2-4 psi or so.� The nice thing with these little booster pumps is that if your mechanical pump ever craps out on you, you just flip a switch and you're back on the road.
edit#2:� Found it:� amazon.com/CarBole-Electric-Universal-Operating-Self-Priming/dp/B01B7DCO6Q/ref=sr_1_8?ie=UTF8&qid=1528072189&sr=8-8&keywords=electric%2Bfuel%2Bpump%2B12v%2Buniversal&th=1
« Last Edit: June 03, 2018, 08:34:13 PM by aboyandhisdog »
« Reply #2 on: June 03, 2018, 07:46:12 PM »
I have mine set up just like Tom - had no issues once I installed the booster as I call it. I do the same thing - when I need it I just flip the switch and I am good to go. I know a lot of guys do not have this problem but I have had issues with mine for as long as I can remember. Even in Texas when it is hot I need to use the electric pump at times.
I'll take a picture of mine so you can see where I mounted it.
« Last Edit: June 03, 2018, 07:47:11 PM by grfranks »
« Reply #3 on: June 05, 2018, 08:51:52 AM »
As promised:
« Last Edit: June 05, 2018, 08:52:16 AM by grfranks »
« Reply #4 on: June 13, 2018, 05:37:01 PM »
That looks like a pretty easy install. Even for old bubba here.  I'll get on it in a week or so and let you know how it goes.  Headed to Canada fishing this weekend so I'll back burner it for a bit.  Thanks guys.
Offline Lee
  • Will-is enthousiast
« Reply #5 on: July 02, 2018, 07:40:56 PM »
Todd, you need a pump that is "Less than 4 PSI" and you will not need a regulator!. I would recommend the settup Tom and Tumbleweed are using, more so if your running the 3A style pump with the vacume settup, they seem very prone to vapor lock above 9000 ft....
Lee ;)
« Reply #6 on: July 19, 2018, 05:36:19 PM »
Thanks for the help guys, bought the same pump, install went well, works like a dream come true !! Back to walking on Sunshine.
Gun
