Author Topic: Filling knuckles  (Read 1928 times)
Offline specialty
  • 1952 CJ3A
Filling knuckles
« on: May 03, 2018, 11:29:04 AM »
Found a good way to fill front knuckles for anyone interested. Thought i would check mine last night and had no way to fill them. So I came across an bottle of Fast Orange hand cleaner that I had bought at Walmart. It pumps the heavy hand cleaner out just fine so I thought why not. It worked great on the thick stuff I use from Mobil. No mess and pumped it full with no guess work. All I used was the pump part after purging the cleaner out.
Offline RandyA
Re: Filling knuckles
« Reply #1 on: May 03, 2018, 10:43:31 PM »
How much lube does it take for the knuckles? And what grade would you suggest? Thanks in advance....
Offline specialty
  • 1952 CJ3A
« Reply #2 on: May 04, 2018, 05:28:40 AM »
I have read about 8 ounces. I just filled mine to the fill plug with a 140 wt. heavy oil from chevron. Really thick heavy stuff but not grease. It will run if given enough time. Many say you can also use John Deere corn-head grease. Chassis grease is not a  good option as it pushes away from the moving parts making it about useless. I suppose the heavy oil will be slung up on the upper king pin bearing so it does not fail.
http://www.greenpartstore.com/John-Deere-Special-Purpose-Corn-Head-Gun-Grease-AN102562.html
Offline RandyA
« Reply #3 on: May 04, 2018, 05:32:37 PM »
Thanks....
