Author Topic: clutch rod length?  (Read 2813 times)
clutch rod length?
« on: August 24, 2017, 11:16:54 AM »
Can anybody tell me the proper length of an OE style clutch rod?  The on-center length would be most helpful.  Thanks.
Re: clutch rod length?
« Reply #1 on: August 24, 2017, 05:36:43 PM »
I got 10 3/8" on center.......on my back, with a tape measure....but I think it's pretty accurate..:)
« Reply #2 on: August 24, 2017, 07:07:24 PM »
Excellent, just what I needed.  Thank you!
« Reply #3 on: August 24, 2017, 08:37:55 PM »
Good! I'm going to make a clevis end rod also..one of these days....
« Reply #4 on: August 24, 2017, 08:52:16 PM »
You know, when I yanked out the old (homemade) rod, the ends were worn down by about 1/3 the diameter.  I'm really glad I found it before it failed on the road.  I made the clevis end rod with 3/8 rod and clevis's from Ace and cut the threads at 3/8 by 24tpi.  With the 10 3/8 measurement you gave me, it basically puts the cross shaft connections in a vertical position and the clutch cable fits correctly.  Factory fresh!
« Reply #5 on: August 24, 2017, 11:15:22 PM »
Nice!
On my 55 CJ-5 the rod was like that, nearly worn to the point of breaking...
On the CJ-3a the hole in the cross-shaft crank was severely� elongated...
You wonder at that design for something that gets lots of use....
I bought some 5/16 fine thread clevis ends and will use 5/16 rod, when i finally remember to buy some....
« Last Edit: August 24, 2017, 11:17:08 PM by 1955CJ-5 »
« Reply #6 on: September 10, 2017, 09:44:10 PM »
Finally made a clevis end rod for the CJ-5 clutch. I shortened it just a little to make up for the elongated holes in the bell cranks...they need to come out some day for repair..
The 3a also needs a new rod, but I repaired the bell cranks when they were out....
Before and after welding, just need to round out the hole....
« Last Edit: September 10, 2017, 09:45:01 PM by 1955CJ-5 »
