Author Topic: Need help with fuel tank venting on CJ3a  (Read 6193 times)
Offline JimW
Re: Need help with fuel tank venting on CJ3aj---UPDATE
« Reply #15 on: April 16, 2017, 10:29:06 PM »
Hi everyone,
I wanted to let you know what I did and what was the outcome.  First off, I now have 3 different gas caps. One is the cap that was on the jeep when I got it. It is old but not an OEM cap. Similar, but slightly different.  The 2nd cap is an OEM reproduction.  Both of these caps are vented. The 3rd cap is one I just picked up from NAPA. It has a chrome top. The box says it's vented, but I can't see any vent holes in the cap.  I tried all three caps with any played with different arrangements of the gaskets.  All 3 leaked.  I had picked up a 1/8" right angle double hose barb that mounts with a nut on the body.  This was not pipe thread type mount but, rather, a UNF thread with nut. I removed the gas sending unit.  I thought I could drill a hole in the top, but the underside of the mounting has a cylindrical part that's attached to the plate. There is a hole in the cylinder, but it wasn't big enough to get a wrench on the hose barb.  I ended up cutting a section of the cylinder out and then drilled a hole in the mounting plate. I mounted the hose barb then replaced the sending unit.  I suspected that since the gas caps were so tight on the tank, I was getting as coming out of the vent hole. I decided to take the original cap and put epoxy over the vent hole.  After letting the epoxy cure, I replaced the gas cap and took the jeep for a drive.  Success!  I did not get any gas coming out of the gas cap. Further more, I did not get any gas coming out of the hose barb. As of right now, I have not put a hose on the barb on the sending unit. I may add that in the near future.  Taking the jeep for a long drive, I did not have any issues, so I must assume the gas tank is venting properly.  I think I'm about to declare victory on this one.  I think there are probably 2 problems with the gas cap, insufficient seal with the gasket and gas coming out of the vent hole(s).  Currently, the gas cap I'm using has 2 gaskets, the original one which is starting to dry out and another one I took off the new OEM style cap that I purchased recently.  So far, so good.  Thanks for all of your experience and suggestions.
Best Regards.........
