Author Topic: Spacer A-8848  (Read 2074 times)
Offline Birddog7
  • Still Plays With Willys
Spacer A-8848
« on: February 15, 2017, 07:42:35 PM »
Need info on above spacer (group 24-7). It goes behind the brass brake line tee on the 3A & 3B Dana 25 axle
Birddog7
1945 CJ2A
1946 CJ2A
1948 CJ2A
1948 CJ3A
1956 CJ3B
Re: Spacer A-8848
« Reply #1 on: February 15, 2017, 08:30:00 PM »
I believe it is just a special flat washer that is used as a spacer behind the tee.
Re: Spacer A-8848
« Reply #2 on: February 15, 2017, 10:19:38 PM »
Here's a photo.� Just looks like a chubby washer.� I think it raises the brake line fitting high enough to reduce brake line interference with the axle u-bolts.�
« Last Edit: October 05, 2017, 01:44:55 PM by athawk11 »
Offline Birddog7
Re: Spacer A-8848
« Reply #3 on: February 15, 2017, 10:54:21 PM »
Thanks Rick, that's what I was looking for. Now I have to go thru parts cans and find that spacer. Bought a new brake line kit try to get the short line to fit right. I figure I need a 3/8ths thick washer to clear the ubolts . The pic helped a lot.
Birddog7
1945 CJ2A
1946 CJ2A
1948 CJ2A
1948 CJ3A
1956 CJ3B
