Author Topic: transmission cross member  (Read 3169 times)
Offline PaulS
« on: July 01, 2016, 09:00:07 AM »
Does the tranny cross member bolt on below the frame, or does it fit inside the frame rails?
-Paul
Re: transmission cross member
« Reply #1 on: July 01, 2016, 10:38:50 AM »
Below the frame...
Will yours fit inside the frame?
Not a great picture but it's all I can find for now...
« Last Edit: July 01, 2016, 10:41:58 AM by 1955CJ-5 »
Offline PaulS
« Reply #2 on: July 01, 2016, 01:49:21 PM »
Thanks!  I didn't measure to see if it would fit--I just tried to insert it, and I was wondering if it needed "persuasion".  But putting it underneath is easier, if that's where it's supposed to be!
It's been so long since I disassembled it, I'm sure I'll have lots more simple questions like this over the next few weeks, as it goes back together.
-Paul
Offline PaulS
« Reply #3 on: July 01, 2016, 01:53:08 PM »
Should have looked in my own archives before posting!
-Paul
« Reply #4 on: July 01, 2016, 10:26:47 PM »
Well, there you go....and your picture is better than mine..
I took a lot of pictures...sometimes I don't know what they were for...but they are fun to look at...
And I put all the nuts and bolts in baggies and then scribbled some gibberish on them assuming I would be able to decipher them months later....
Offline specialty
  • 1952 CJ3A
« Reply #5 on: July 02, 2016, 02:56:59 AM »
I did the same thing with the bolts and some parts thinking 6 months down the road I could remember what I was doing when I forget what I did 10 minutes ago sometimes. I just took lots of pictures and emailed them to myself for reference. That helped more than anything. Things I missed I would google and find pictures to go by. Good luck.
Offline PaulS
« Reply #6 on: July 02, 2016, 10:45:49 AM »
I have lots of pictures, too, but I didn't always take pictures where I should have.  I'm expecting to have trouble reassembling the clutch and the pedals and linkages around there...
When I pulled apart the engine, transmission, and transfer case, I was very diligent about using baggies.  And those (mostly) went back together without problems.  But I didn't use baggies when I pulled things off the frame.
-Pau
