Author Topic: Tub rebuilders! What gauge sheet metal?  (Read 3671 times)
« on: May 04, 2016, 04:43:20 PM »
Hello all, this is a question for you tub fixer uppers / rebuilders.
I called around for some sheet metal today and I'm fixin' to get two 4x8 sheets of steel. But I have a question regarding gauges (thickness):
I know that most of the tubs were made with stuff close to 18 gauge, but that is thick stuff, and I'm agonizing whether I should go with 20 gauge to make life easier. Which thickness should I get?
I need to make front floors, and at least one whole side of the tub, the rear panels (tail light areas) wheel house sides, and the step up piece between floors.
(I'm using pickup bed floor metal I scavenged for my rear floor...it's nicely corrugated)
Would 20 gauge just be too wimpy? I am going to make hat channels out of 1x2 square tubing by the way.
If you have any wisdom, been there / done that comments, I'd appreciate it.
Re: Tub rebuilders! What gauge sheet metal?
« Reply #1 on: May 04, 2016, 05:57:17 PM »
I used 18ga...not that hard to work with...
I found 16ga difficult with the tools that I had..
I bought some 20ga but used very little as it was just too thin...I think I used some on the front fender flange repair..
I think you would have a lot of oil-canning if you used 20ga in the floors...
« Last Edit: May 04, 2016, 06:01:25 PM by 1955CJ-5 »
« Reply #2 on: May 04, 2016, 07:57:18 PM »
I agree with 1955CJ-5.  20 gauge could be problematic.  I chose 16 gauge for my repairs.  It harder to cut and bend, but easier to weld without oil canning and warping.
I measured steel thickness on 3 different tubs in 3 similar spots.  These 9 measurements averaged .0518".
16 gauge is suppose to be .625" ish
18 gauge is suppose to be .049" ish
Coincidently, the sheet of 16 gauge steel I used, measured out to be .0570".  A little thinner than .0625".
Hawk
« Reply #3 on: May 04, 2016, 09:20:12 PM »
Thanks gents for the quick response.
You're comments convince me to just go with the 18 gauge.
Thankfully most of the bending required will be simple 90 degree bends. I'm dreaming up some fixturing to make the rear "quarter" curve/wraparound at the back.
Hopefully I'll be posting soon with some metal work. I absolutely devoured the tub rebuilds I've seen on here and the '2a site. Amazing work out there.
« Reply #4 on: May 04, 2016, 09:54:35 PM »
To make the curves for the rear panels I bought a 6" or 8" diameter(I forget, so you need to measure...) length of PVC, then filled it with post hole concrete, because it flexed to much and that was my form....I'll look for a picture....
Found some...
« Last Edit: May 04, 2016, 10:01:28 PM by 1955CJ-5 »
« Reply #5 on: May 04, 2016, 10:04:40 PM »
One little thing that i learned about forming metal....
You can ease it a little, massage it a little, let it rest and then move/form it a little more....just don't try to force it to do something all at once...
"Malleable" will take on a new meaning for you....
Offline JeepFever
« Reply #6 on: May 05, 2016, 12:32:46 AM »
I agree that 20 would be too thin.
I used a couple sheets that have been around my garage for years.  One was .050,  and one was .057. . .  unfortunately for me,   by the time I got to doing the passenger rear quarter,  all I had left was the .057.  For me,  that was a PAIN to bend into shape.  ;D
My floor patches are .075  :o  . . again, because I had a bunch of it.   No oil-can in those floors.   ;D
Tonite I just cut out some of front fender,  I measured .038 in an unrusted section.
