Author Topic: Hand Brack Cable End  (Read 3582 times)
Offline JimVillers
« on: March 21, 2016, 06:10:00 PM »
I have another stumping question.� What does the cable end connection look like?� It it available?
The hand brake cable sheath needs to be secured somehow.� The parts book indicates a clip on the flywheel for a CJ2A and nothing for a CJ3A.� I found several images on the 2A web site showing a special bracket and a bracket attached to the side of the air filter bracket (2A web site thread: http://www.thecj2apage.com/forums/hole-in-air-filter-bracket_topic19373.html).
What is the correct?� Also, I put a wire clip on the right side harness as it looked like it needed support; is this correct?
« Last Edit: March 21, 2016, 06:10:55 PM by JimVillers »
Jim Villers
Virginia Beach, VA
Re: Hand Brack Cable End
« Reply #1 on: March 21, 2016, 07:18:08 PM »
Something is missing there...
This first picture might not be clear enough, but there ought to be a bracket on the firewall..I'll look for another picture....I don't remember what I was pointing at or why...
The second picture shows a clip I added to the bellhousing..there already was a hole there...mine was plain but apparently on some they are threaded..you could easily thread it though...
« Last Edit: March 21, 2016, 07:20:07 PM by 1955CJ-5 »
« Reply #2 on: March 21, 2016, 07:26:08 PM »
Here, this shows it better....I think that air cleaner bracket is just hanging there..it doesn't look right...
Do you still have your old tub?
« Last Edit: March 21, 2016, 07:29:58 PM by 1955CJ-5 »
Offline JimVillers
« Reply #3 on: March 21, 2016, 07:50:31 PM »
Perfect .... I have that bracket that I thought was for a return spring.  I also have the clip because it is the same clip that in attached to the frame member and I bought a new one to replace my bent one.
I appreciate all of your help.
I guess that the wiring harness clip does not fit now that the bolts are used for the bracket.
Jim Villers
Virginia Beach, VA
« Reply #4 on: March 21, 2016, 08:12:34 PM »
One of those wires routes around behind the air cleaner...
I think Nate posted a picture on the "From the Factory" section...
Here it is..
http://www.cj3apage.com/cgi-bin/3Ayabb26/YaBB.pl?num=1374236690
« Last Edit: March 21, 2016, 08:17:23 PM by 1955CJ-5 »
Offline JimVillers
« Reply #5 on: March 21, 2016, 08:54:54 PM »
Thanks for the additional link, just what I needed.
Now another question, is there a buffer of some sort on the hand brake where it contacts the dashboard?  I think that it needs a felt ring.  I could expand the hole and put a rubber grommet.  What is "normal"?
Jim Villers
Virginia Beach, VA
« Reply #6 on: March 21, 2016, 09:07:24 PM »
Now another question, is there a buffer of some sort on the hand brake where it contacts the dashboard?� I think that it needs a felt ring.� I could expand the hole and put a rubber grommet.� What is "normal"?
I bought a couple of packages of these..
http://www.lowbrowcustoms.com/leather-washers-1-diameter-x-1-8-thick-with-3-8-hole-10-pack.html
I put them everywhere, including under the parking brake handle....I may have opened the hole a bit....
I used several on the rear view mirror...
« Last Edit: March 21, 2016, 09:12:43 PM by 1955CJ-5 »
