Author Topic: L134 Block  (Read 3498 times)
Offline Austin
L134 Block
« on: February 09, 2016, 10:42:14 PM »
I have this extra block that I did not end up building because of a crack in the oil galley (I think that's what it's called under the valve cover.) I think a couple of the head bolts have been drilled out and taped to accept a larger bolt and I believe that it would need to be bored to a 3 over. The machinist told me that it could be used, although it is not a ideal block. I am on the fence about scraping it. Would anyone use this block or is it scrap metal?
Offline Austin
Re: L134 Block
« Reply #1 on: February 09, 2016, 10:43:03 PM »
Re: L134 Block
« Reply #2 on: February 09, 2016, 11:41:12 PM »
I would have a hard time scrapping any L-134 block, but maybe I'm a little sentimental about them. There is a finite number of these blocks.  If the machinist says it's usable, I would not let it go quite yet.  Only .030 over tells me that block still has a lot to give.
Re: L134 Block
« Reply #3 on: February 10, 2016, 06:00:22 AM »
I agree with Tim. They aren't making them new anymore.
Re: L134 Block
« Reply #4 on: February 10, 2016, 08:37:55 AM »
x3
Offline Jesse
Re: L134 Block
« Reply #5 on: February 10, 2016, 10:33:14 PM »
I would keep it. I traded a ww2 production block in at Midwest Military and I was shocked that he wanted it given the number of cracks between the cylinders. I figured it had gone its last mile. But there is a lot that can be done to save an engine block if you really want to.
-Jesse
« Last Edit: February 10, 2016, 10:33:50 PM by Jesse »
Re: L134 Block
« Reply #6 on: February 11, 2016, 10:15:00 AM »
Almost any damage can be repaired on cast iron blocks if your in need of one. Put it on ebay or here and see what comes up. I would not scrape it. I scraped out a CJ2A and kept the engine and tranny assembly as well as other parts for future use or sale. I also have a bare block that was original with my Jeep.
