Author Topic: steering column  (Read 3977 times)
Offline specialty
  • 1952 CJ3A
steering column
« on: February 09, 2016, 06:17:56 AM »
Question on the top steering column bearing. Those ones that you can buy look pretty weak to me. Anyone ever make one out of bearing bronze or oil-lite to make a good durable bearing? Or maybe a good sealed bearing to replace the original?
Also should I go ahead and install the column
BEFORE putting the tub back on? I notice most have their columns installed before. It looks like it would be much easier to do it before to get everything adjusted right than after. Thanks
Re: steering column
« Reply #1 on: February 09, 2016, 01:10:52 PM »
Can't help you on the bearing, but you can install the column after putting the tub on. That's what I do. The hole is slightly small for the triangular piece, but you can make it fit.
Re: steering column
« Reply #2 on: February 09, 2016, 01:11:50 PM »
What does the stock bearing look like?
Offline specialty
  • 1952 CJ3A
Re: steering column
« Reply #3 on: February 09, 2016, 07:48:48 PM »
You can do a google search to find a picture. My column has one in the top but unless I am missing part of it it does not touch the column at all and does nothing. It looks like the picture though.
Re: steering column
« Reply #4 on: February 10, 2016, 06:03:45 AM »
I suppose you could make one from bearing bronze.
Re: steering column
« Reply #5 on: February 10, 2016, 10:19:15 AM »
Here is one that is apart...
Maybe you are missing part of it?
Offline specialty
  • 1952 CJ3A
Re: steering column
« Reply #6 on: February 10, 2016, 07:57:03 PM »
After seeing your pictures I am missing about all of it. The only piece I have is the one that taps into the column. Thanks
Re: steering column
« Reply #7 on: February 10, 2016, 08:46:49 PM »
Glad to have been able to help!
They are not the greatest bearing but they don't carry much load....a little light grease when you put it together and it should work fine...
Offline specialty
  • 1952 CJ3A
Re: steering column
« Reply #8 on: February 11, 2016, 02:53:40 AM »
Serves the purpose I guess. I might just see if I can find a sealed bearing to do the job or make up a oil-lite bushing. Thanks for the information, now I know what was in there.
