Author Topic: New Manifolds - Trouble aligning  (Read 1826 times)
Offline ChrisD
« on: December 05, 2015, 04:11:23 PM »
Guys, I have new intake and exhaust manifolds that I am trying to install on my 1950 CJ3A. The manifolds will not align flat to the block once I bolt them together. I have already cracked one intake manifold because I did not check it before bolting it up.
Is there a trick I am missing??
Chris
Chris D.
1950 CJ3a
Houston TX area
Re: New Manifolds - Trouble aligning
« Reply #1 on: December 05, 2015, 05:19:09 PM »
There are 4 bolts where the intake and exhaust bolt together with a gasket. Can you loosen them and then bolt the pair up flat on the engine, then tighten the 4 ?  Also where the two bridge on the lower bolt line, a heavy thick washer is used there. If this fails, then you need to have the surface planed or milled. John
Offline ChrisD
« Reply #2 on: December 05, 2015, 09:36:29 PM »
John, thanks - I did not know about the thick washer. I will loosen the bolts and see if I can bolt up to the engine. I will probably be visiting the machine shop this week to get it planed.
Chris D.
1950 CJ3a
Houston TX area
Offline ChrisD
« Reply #3 on: December 22, 2015, 11:22:18 AM »
Took the manifolds to my local machine shop. They had to drill out the holes where they bolt together and then re-surfaced it flat.
Chris D.
1950 CJ3a
Houston TX area
