Author Topic: Steering wheel removing  (Read 5908 times)
Offline Linda
« on: September 01, 2015, 01:08:01 AM »
Hi, would someone tell how to remove the steering wheel off . I got parts to rebuild steering box, But can't get pass first base. Thanks for any help.
Offline Dutch_Jeeper
Re: Steering wheel removing
« Reply #1 on: September 01, 2015, 03:26:53 AM »
http://www.cj3b.info/Tech/SteeringWheel.html
You could try it once with a firm tap with a rubber mallet after applying penetrtating oil for a few days and hope it pops out, if not use  the method above or you will destroy the steer and/or shaft.
« Reply #2 on: September 01, 2015, 01:50:45 PM »
I used a Harbor Freight bearing puller, #30305......worth the money i think..I've used on a number of other things..
Stick a bolt inside the steering tube for the puller's center threaded rod to push against.
It takes time. I think I put the puller on and just left it under tension over night and then tightened it a little more a little at a time and eventually it popped off.
Use lots of penetrating oil as previously mentioned
« Last Edit: September 01, 2015, 01:52:09 PM by 1955CJ-5 »
Offline Linda
« Reply #3 on: September 01, 2015, 02:49:35 PM »
Thanks for the suggestions, I have been applying penatrating oil for several day . I� tried the bearing puller method and no success .I have the puller on it now with tension on it. Every time I go by ,I give it a shot of oil. Is the horn button the only thing that holds it on. I thought maybe Iam missing something. HELP!!!!!!
« Last Edit: September 01, 2015, 02:51:14 PM by Gramps1 »
« Reply #4 on: September 01, 2015, 05:08:58 PM »
Hi Linda
 I ruined my steering wheel and my steering shaft and learned a lot. I used penetrating oil for weeks, tried a puller system that others used and still had a problem.
 My boss at the garage I have worked at part time for years told me a trick that worked for him in the past.
 By grabbing the wheel at the 9 o'clock and 3 o'clock positions press down on one side and then lift the opposite side. Alternate hand positions like 12/6 8/2 etc and continue, after "breaking contact" then lift on wheel, important to remember to leave the nut on the shaft a few threads at this point.
 Good luck, they are a pain.
 Kirk
« Reply #5 on: September 01, 2015, 06:28:06 PM »
When you have tension on the puller, try giving the center threaded rod a good rap or two with a hammer....start easy...sometimes that is enough to shake things loose
Offline Linda
« Reply #6 on: September 13, 2015, 10:37:13 PM »
Hi,folks. I tried all your methods and it didn't budge. I
Was ready to get the hack saw out,I took the puller off and gave it the around the clock pull method and it popped off in my hands. I want to thank all of you for your help.
« Reply #7 on: September 14, 2015, 09:30:24 AM »
Good going!! That's a hard one!
« Reply #8 on: September 14, 2015, 03:17:02 PM »
Yes nice work...and thanks for the follow up.....it's good to know how things turned out..
I put a little anti-seize on my steering wheel splines when I put it back together...
Offline JimVillers
« Reply #9 on: October 11, 2015, 08:12:35 PM »
Mine was STUCK!  I ended up cutting a slice in the wheel with a die grinder and then splitting it with a chisel.  It was still hare to remove, even with penetrating oil and lots of rocking.  I destroyed the wheel but saved the shaft.
Jim Villers
Virginia Beach, VA
Offline JimVillers
« Reply #10 on: October 11, 2015, 08:13:42 PM »
Jim Villers
Virginia Beach, VA
