Author Topic: L134 Engine ID  (Read 3223 times)
Offline Dre
L134 Engine ID
« on: September 23, 2015, 12:35:33 AM »
I have started cleaning all the goo off the engine today so I can start tearing it apart just to check if it is salvageable and discovered that the engine does have an M38 casting on the block and head. Block casting is 804 380 and head is 800376. Serial number is 4LR136591. Can you help me ID this engine? I'd like to see if I can find out where it came from.
thanks,
Re: L134 Engine ID
« Reply #1 on: September 23, 2015, 04:49:31 AM »
Probably not everything you want to know but start here;
http://www.ww2jeeps.com/htm/Lheadmain.htm
Re: L134 Engine ID
« Reply #2 on: September 24, 2015, 12:20:19 PM »
"4LRxxx" would make it a replacement block.
Offline Dre
Re: L134 Engine ID
« Reply #3 on: September 28, 2015, 01:28:45 AM »
Really? Very interesting. I'm still going to attempt the engine revival process even though I suspect that it has been sitting with it's head off for a while.
Re: L134 Engine ID
« Reply #4 on: September 28, 2015, 09:10:56 PM »
As Ryan said it's a replacement engine. It would have been a short block made in approximately the late 1950s.
What are the numbers and letter cast in the block on the drivers side down low near the rear?
Offline Dre
Re: L134 Engine ID
« Reply #5 on: September 29, 2015, 12:35:00 AM »
all I've got on the left side is 12 and T
