Author Topic: Wheel's & Tires  (Read 2393 times)
Offline gsollenberger
Wheel's & Tires
« on: September 03, 2015, 10:54:53 AM »
I have not had a chance to fully think this through, but figured I would ask the experts here first  :)  Question about wheels and tires - I have a 1950 CJ3A that is stock.  I am wondering if wheels and tires from a 69 CJ-5 will fit?  Is the lug pattern the same on the 3's and 5's? The tires off the CJ-5 are 78-15's.
Thanks!
Offline Dutch_Jeeper
Re: Wheel's & Tires
« Reply #1 on: September 03, 2015, 02:45:22 PM »
As far as the lug pattern is concerned it's 5 on 5.5 :
Jeeps with 5 on 5.5" Bolt Pattern:
* 46-86 CJ (All Models)
* 63-73 Full Size Cherokee/Wagonner (SJ)
* 62-71 Galdiator Series Truck (All Models)
Not sure about the offset between different models.
If you are not going stock, 5 on 5,5 is also the same lug pattern as on early Suzuki Samurai's, if your looking for something different.
Largest tires you can fit without lift and clearance issues is 31 x 10.5 i believe, not entirely sure on that one though.
Re: Wheel's & Tires
« Reply #2 on: September 03, 2015, 08:25:49 PM »
I've exchanged the 15" wheels and tires on my 3a with the 16" wheels and tires on the CJ-5. They bolt up and work fine, but both are narrow tires....215 radials on the 16" rims and 7:50 NDCC on the 15's
