Author Topic: 20-25MPH Shake  (Read 8328 times)
Offline Austin
20-25MPH Shake
« on: August 10, 2015, 11:32:33 AM »
I have been driving my 3a for a while now. It has always has a severe shake form 20-25MPH. As soon as I get over 25, the shake goes away. I have never really been bothered by this, but now my girlfriend has started riding with me. She loves going out on long rides on the weekend but hates the shake. Any ideas about what could be causing this shake? A little background: There some free play in my steering wheel, and my wheels are not balanced.
Offline Dutch_Jeeper
Re: 20-25MPH Shake
« Reply #1 on: August 10, 2015, 01:13:20 PM »
Sounds like the start of shimming or deathwobble, it will get worse over time.
Not sure about the free play in the steering wheel being the cause, might try a tight steer. But definately get your tires balanced and have the jeep alligned. Also check wheel bearings and tierod ends for play.
I assume you have not lifted the CJ3, but deathwobble is a common problem with lifted Jeeps. The slightest play in any part of the entire axle assembly (from wheel bearings to tie rod ends, to pitmanarm) can cause it, usually after hitting a bump, even the smallest bump on a flat road. The bump causes the entire axle to start shacking violently, up to the point your thrown around in your Jeep and usually only a full emergency stop will stop it.
https://www.youtube.com/watch?v=ncZDRStpFms
As you can see it does not matter if you have coilsprings or leafsprings
Most people install a steering damper and it's gone, but this only camouflages the problem, it does not solve the problem and it will return eventually, probably worse.
Besides play in any part, however small, the biggest issue is the caster that changes after lifting a Jeep. The top of the axle tilts forward and it gets a negative caster. You want caster to be at least neutral or best positive. In Jeeps like the TJ you need to install longer lower suspension arms, most people do not and it keeps coming back. If you have negative caster, the front axle basically starts acting like a shopping trolly with one wheel stuck that starts to flutter and you cannot steer until you stop and go again.
Now i'm not to familiar with the Willys yet as in how far the above translates to the Willys deathwobble or shaking symptoms. Mine also has steering wheel play and there is a litlle bit of play on one tierod end but no wobble or shaking at all, not even on uneven or bumpy paved roads. I did have the tires balanced and had it alligned.
So i advice to do that first before you start replacing parts. You can do the alligning yourself with a string.
Just the first hit i got on youtube:
https://www.youtube.com/watch?v=AuYsd7SUwTA
« Last Edit: August 10, 2015, 01:22:09 PM by Dutch_Jeeper »
Re: 20-25MPH Shake
« Reply #2 on: August 10, 2015, 01:45:35 PM »
You need to check the king pin bearings for this problem. The bearing races will show signs of brinelling I'm prestty sure. Just do a search and you will see a number of posts on this common issue. New bearing, races, and proper shims should solve your problems.
http://i863.photobucket.com/albums/ab191/rocketeer_2010/Jeep/shimmy.jpg
Re: 20-25MPH Shake
« Reply #3 on: August 10, 2015, 02:59:29 PM »
All good points from above.  One other easy thing to check, which also causes this phenomenon, is when the drive shaft is 'out of phase.'  Or bent/damaged.
Here is a link discussing driveshaft phase...
http://www.thecj2apage.com/forums/loud-but-elusive-noise_topic16393_post142906.html?KW=out+of+phase+driveshaft#142906
Re: 20-25MPH Shake
« Reply #4 on: August 10, 2015, 03:07:12 PM »
I'd be leaning heavily towards tire balancing or Tim's suggestion of driveshaft phase. A death wobble is not something you just "drive out of" by increasing the speed. You typically need to bring the Jeep to a near stop to get it to come out of it. Trying to accelerate out of a true Death Wobble will feel like the vehicle is going to rip apart - it's not fun.
Re: 20-25MPH Shake
« Reply #5 on: August 10, 2015, 04:59:53 PM »
Start with getting the two truest running wheels up front. If they wobble or the tires are out of true themselves, it will start the wobble. Then try and get rid of where the slack is, like the bellcrank shaft. Then the knuckle bearings as indicated. The steering box itself may have worn sector shaft and bushings. The draglink may also have broken springs inside and is now too loose. Don't waste your money on a steering stabiliser shock. They don't help much. Last is the caster. Sagged springs up front will do this. Sometimes a simple wedge shim will help give you caster. John
Offline Austin
Re: 20-25MPH Shake
« Reply #6 on: August 11, 2015, 09:13:05 PM »
Thanks all. I am going to attempt a alignment and have the wheels balanced this week. Thanks Tumbleweed for "The Shimmy Page." I found a king pin bearing kit from Kaiser Willy's Auto Supply. I'm going to go ahead and put my order in. Should be a good weekend project.
Re: 20-25MPH Shake
« Reply #7 on: August 11, 2015, 10:08:08 PM »
If you can feel the shake through the steering wheel then most likely it's in the front end..a knuckle rebuild makes a big improvement..
If it is just a general sort of rumble/shake try the drive lines..check both  front and rear for phase as Tim recommended if you don't have lock-out hubs..
Offline Austin
Re: 20-25MPH Shake
« Reply #8 on: August 12, 2015, 06:27:12 PM »
anything else I should replace or look at while I have everything apart?
Re: 20-25MPH Shake
« Reply #9 on: August 13, 2015, 11:39:56 PM »
Well, where to start?
Rebuild the steering box, bushings, sector shaft and seal, if you are lucky you won't need a worm shaft.
Rebuild the bellcrank.
Check the pitman arm and bell crank ball ends for wear..if flat on one side or way out of round replace.
Rod end bearings..
check the wheel bearings and seals.
Knuckle bearings too.
I replaced everything in my CJ-5 and STILL the steering was very stiff....but the knuckle rebuild solved all that...
good luck!  Well I can't find an exploded knuckle picture....the Jeep Manual  gives a good explanation though
Offline Austin
Re: 20-25MPH Shake
« Reply #10 on: August 14, 2015, 07:30:43 AM »
Thanks. I found some good illustrations on the knuckle rebuild. Still not sure what the torque should be on the bolts on the king pin bearing cap. I understand that I need to use the spacers and a fish scale to have 16 pounds that moves the knuckle.
I also went ahead and ordered the wheel bearings and seals.
I am thinking about ordering new king pin bearing caps for the top. Is this necessary??
Re: 20-25MPH Shake
« Reply #11 on: August 14, 2015, 08:41:02 AM »
Austin,
The more modern manuals to suggest the higher pre-loads, but I'm not sure I would set it to 16 lbs.  Your bearings will sound kind of crunchy.
Older manuals had the pre-load specs much lower.  I split the different recommendations and settled on 10-12 lbs.
Offline Austin
Re: 20-25MPH Shake
« Reply #12 on: August 14, 2015, 09:00:28 AM »
Should I order new king pin bearing caps for the tops of the knuckles?
Re: 20-25MPH Shake
« Reply #13 on: August 15, 2015, 12:05:08 AM »
Do you mean the part that bolts on with the four bolts or studs and has the pin? I'm not sure what it is called...
I did not need any for either jeep..all four were fine...get shim packs though...
Offline Austin
Re: 20-25MPH Shake
« Reply #14 on: August 15, 2015, 06:50:40 AM »
The bolts I was asking about are the four bolts that go in the top of this part. I think it's called the king pin bearing cap. I ordered the shims.
