Author Topic: Help! 51 CJ3A  (Read 109198 times)
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #270 on: April 18, 2015, 10:04:13 PM »
Grinding when it goes in gear bad. Should the throw out bearing spin or not?
Re: Help! 51 CJ3A
« Reply #271 on: April 18, 2015, 10:57:18 PM »
The throw out bearing should only spin when you depress the clutch. When your foot is off the clutch pedal the throw out bearing should not touch the pressure plate and should not spin..see Tim's video...
https://www.youtube.com/watch?feature=youtube_gdata_player&v=LnyHEJPsivk&app=desktop
« Last Edit: April 18, 2015, 11:06:56 PM by 1955CJ-5 »
Re: Help! 51 CJ3A
« Reply #272 on: April 18, 2015, 11:13:50 PM »
As for that noise.....I cannot tell you exactly what it is, but I know it is not normal...it could be a bad throw out bearing or pressure plate....
If you decide to replace the clutch it may be easier just to pull the engine as you have had it out recently....
Replace the clutch AND the pressure plate and the pilot bushing...do not do one at a time, and consider having the flywheel surfaced.....mark the flywheel when you take it off so you can get the timing marks where they belong when you put it back together...
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #273 on: April 19, 2015, 12:36:18 AM »
Transmission bolt broke off so it wasn't in place right. Guess what?!?! She's running!!! Even Got her a little muddy! Checked the oil after and its milky so I'm going to replace the head gasket but thank you all so much. Could not have done this with out you guys. I'm sure I'll be back on here in a few days with questions but I'm so happy to have her running again!
Re: Help! 51 CJ3A
« Reply #274 on: April 19, 2015, 06:39:16 AM »
Congrats on your running Jeep! You may want to run it a little more before tackling the head gasket. I've seen milky oil clear up with a short amount of run time after the engine has sat or been worked on extensively.
Re: Help! 51 CJ3A
« Reply #275 on: April 19, 2015, 10:20:14 AM »
Congratulations.
I agree with Ryan.  Run it for some miles, change the oil, then run some more.  Check for milk.
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #276 on: April 19, 2015, 11:32:06 AM »
Thanks. I will definitely do that. How many miles you think?
Re: Help! 51 CJ3A
« Reply #277 on: April 19, 2015, 11:44:36 AM »
Tough to say exactly. A couple hours run time and an oil change should show remarkable improvement if that's all it is.
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #278 on: April 19, 2015, 01:54:48 PM »
Just checked the torque on the head. Little loose. Maybe that will help?
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #279 on: April 20, 2015, 02:37:14 PM »
When I say milky I mean really milky! Alot of White. I'm gonna change the oil before I start it again but how concerned should i be? Also one of the studs broke when I was torqueing it down to specs. How bad is that? Yes  I used a torque wrench.
« Last Edit: April 20, 2015, 02:43:46 PM by Taber12112 »
Re: Help! 51 CJ3A
« Reply #280 on: April 23, 2015, 11:42:25 AM »
SSG,
The development of moisture inside an engine block is not uncommon.  Especially in a region with high humidity.
Moist air is being pulled into the block at all times.  This will eventually condensate with changing temperatures.  A running engine will displace this build up of moisture eventually, but it can take time.
You may have a problem with the head seal, or a crack in the block, but you generally don't want to start tearing into it until you've exhausted other possibilities.
The broken stud is a problem.  That's a real bummer.  Opinions may vary, but  I would pull the head and replace it before moving forward.  Not a fun job.
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #281 on: April 23, 2015, 12:18:51 PM »
Thanks Tim. The stud isn't broken its just stripped. Its at about 48 with torque  wrench. Ordered a stud and head gasket but since its still in semi tight should I make this a priority?
Re: Help! 51 CJ3A
« Reply #282 on: April 23, 2015, 12:24:44 PM »
Well, that's better news.
Do you have good threads up higher on the stud?  If so, I might consider adding a couple washers to space the nut up higher on the stud, then torque to the minimum required.
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #283 on: April 23, 2015, 12:44:41 PM »
Wow good idea! Try it tonight!
Offline SSG T
  • Hooah
Re: Help! 51 CJ3A
« Reply #284 on: April 23, 2015, 08:34:11 PM »
So I replaced the temp gauge and oil and started it her up to see if it worked and that head stud *crap itself out of the hole followed by water....the way it shot out almost made me laugh.....almost
