Author Topic: Bellcrank install and torque  (Read 20580 times)
Re: Bellcrank install and torque
« Reply #15 on: December 08, 2013, 09:43:24 PM »
I think it's odd that Walck's offers the identical kit for 2a's, 3a's, FC150's, M-38, etc etc, yet there is no extra dust seal or washer for that gap....
Where's Bretto? Doesn't he have an M-38?
« Reply #16 on: December 09, 2013, 11:36:34 AM »
I agree with Randy.  I think Bretto is our key.
This could have been a design change, but why would everyone sell the same repair kit that is interchangeable between so many different Willys versions?
« Reply #17 on: December 09, 2013, 11:51:57 AM »
Here is a picture of Bretto's frame.� This tells me it is conclusive that there was a design change for the M38.� Is there some type of shim pack available?
« Reply #18 on: December 09, 2013, 12:23:40 PM »
I went through Bretto's build pics but I guess I didn't go back far enough.
That picture clearly shows a bushing or sleeve..
Ryan's post on the willysmjeeps forum got a response that shows some special washers/shims/spacers in there...here is the picture
I think Ryan needs to call Carl or John Bizal....
« Last Edit: December 09, 2013, 12:24:31 PM by 1955CJ-5 »
« Reply #19 on: December 09, 2013, 12:49:33 PM »
There was a change. I'm still not sure if my bracket "sleeve" is correct but there did appear to be that protrusion there - whether sleeved or originally cast. The parts diagram for the M38 also shows a spring washer (which I don't have) and the thicker boot/seal that I do have in my pic. Those are parts #9 and #10 in the M38 diagram. If I can find a suitable spring washer replacement I think it'll be OK.
I am still a big fan of Walck's, but the "Bell crank kit 7/8" CJ2A, CJ3A, CJ3B, CJ5, CJ6, DJ, FC 150, M38, M38A1 Part Number: 920556" is another part that should not be advertised as completely suitable for the M38.
« Last Edit: December 09, 2013, 12:58:11 PM by Ryan_M »
« Reply #20 on: December 09, 2013, 08:08:31 PM »
Here is an M38 bellcrank bracket. It's difficult to see in the photo but the shoulder is part of the bracket and that's where the seal rides. The seal has a metal "spring" around it to provide more pressure on the sealing surfaces.
« Reply #21 on: December 09, 2013, 08:41:09 PM »
Interesting. My seal does not have that spring. Is that the "6. SPRING, TENSION, SEAL" in the M38 Fig. 24 above? Fig. 24 seems to show #6 above the #7 seal but maybe it was meant to wrap around it?
I'm confident I can make my set-up work and I'm pushing this now solely out of curiosity. See what happens when you guys allow this step-child 3A variant to hang with the 3A family?�
« Last Edit: December 09, 2013, 08:42:05 PM by Ryan_M »
« Reply #22 on: December 09, 2013, 09:23:48 PM »
I wouldn't have it any other way!� 8-). We're all learning new and interesting variants.�
Now, the million dollar question...�
What advantage/improvement does this design change offer?
The M38 was designed to "ford".� �Assuming all the seals are correct and fresh, would this be more water tight?
« Reply #23 on: December 09, 2013, 11:22:46 PM »
Interesting, isn't it?
I think of the M-38 as a military CJ-3a but there are probably more differences than there are similarities.
I have a friend who has one and he swears it drives better than any CJ....maybe the steering box to bellcrank geometry is just a little different..
« Reply #24 on: December 10, 2013, 10:44:37 AM »
I suppose the M38 would be more water tight with the added seal and spring. I know when I sloshed through deep water in my 3A last year I saw A LOT of water squeeze out of the bell crank when I regreased it.
I plan on taking the M38 on the same trip next year so I'll be able to compare test results....
« Reply #25 on: June 01, 2015, 06:49:46 AM »
Interesting thread, I am intending to install the bell crank repair kit today� hopefully its pretty straight forward... ::)
« Reply #26 on: June 01, 2015, 08:01:46 AM »
Nothing can be straight forward can it?
No what pray tell....
« Last Edit: June 01, 2015, 08:02:23 AM by Kirkski »
« Reply #27 on: June 01, 2015, 08:36:10 AM »
Pressing, pounding etc ... Any words of wisdom here? Nothing on the web that I have found...
